LT4 Rods in LQ9 Build
Ive got 2 builds happening right now. A budget 6.0 and a not so budget 6.0. For the not so budget Ive picked up Lunati H beams.
Would these be suitable for the budget build? What material are they? Since theyre ina 650hp factory car, and theyre factory rods, would it be reasonable to suspect they'll hold even more HP. Most know how strong the stock bottom is.
Thoughts? I tried searching and couldnt find much.
So I'll just buy hyper-e pistons for the "budget build" in stock LS1 stroke.
It surprises me they went to .943 and a steel rod when the LS9 was .984, 5.990 and Ti.
Remember the lsa uses a big gen4 rod basically.
Right, should note I measured with the bearings in
Not the first time whats published isnt correct. Those are actual measurements as well.
