New engine cranking issue
Fuel is getting to the rails, and I have good compression, and what looks to be a descent spark. I used a spark tester from auto zone and I could see a spark but it was intermittent. After around 5 rotations of the engine, it will blow a puff of air through throttle body.
I also noticed that before, when I would crank it, it would fire plugs once but not after. That was yesterday but today it seemed to be firing more than once
it's almost like coils are firing backwards, even though there is no possible way to reverse harness as it carries all it's injectors and accessories with it. Possible incorrectly manufactured harness?
my biggest fear is that the reluctor wheel is damaged and not reading correctly. Hopefully not.
any help or advice would be great.
I was a bit skeptable first as I had descent compression but I'm not even sure if 170 is as high as it should be
popping through intake intake and exhaust leads me to believe my custom harness might have been defective as far as coil plugs etc. I'm going to throw my diagnostics tool on there and check all the parameters.
if anyone has any suggestions at all or ideas on how to confirm that coil harness is reversed, please let me know. I can't just swap them unless I find an extension, which I will use to fire it up and then rework the harness my self.
while cranking, it pretty much sounds exactly like a firing order issue like on the older distributor motors.
any help is appreciate
crank sensor is just an off the shelf ict billet sensor from summit ICT Billet Crankshaft Position Sensors 551222
cam sensor: ACDelco Camshaft Position Sensors 12561211
My top cam gear is a comp dual unit.
