Ls1 build. What parts do I need to replace?
An oil pump upgrade is never a bad idea, nor is a good timing set. If you can spring for some better lifters (and roller rockers) you'll have better longevity and stability out of your valvetrain.
What are your power goals with this system? Through an automatic or manual trans?
My 99 TA had 165,000 miles on the old LS1 about 133,000 of that with heads & cam with 4.10 gears. That's close to 200,000 miles in rpm with stock gears. The old LS1 runs well and is probably getting swapped as is to another car with the bottom end as is.
I would leave the Rod bolts alone in less you have the rods resized. Changing bolts can distort the Rod when tightened up. Some get away with it some don't.
I would check the heads carefully before using - mine have a replacement valve. I picked up an LS2 block from the same vendor. It's a good block just needs to go .010 over for clean up.
Melling oil pump, - probably not needed, especially with 85k
LS2 timing chain, - same as oil pump, but inspecting the guide wouldn't be a bad idea.
ARP head bolts, - They're good peace of mind if you think you may be pulling heads often, but otherwise stock bolts are fine for your intended use. ARP = pricey.
New coil wires, - can't hurt, but probably not necessary. I'd save that for when you're bored later
New harmonic balancer bolt, - only if you're removing or replacing the balancer. If it ain't broke, don't fix it.
trunion rock arms, - Yes
LS7 lifters, - as long as your spring pressures aren't too high, Yes
push rods, - not 100% necessary, and an easy upgrade later if you feel you need them
ASA high lift cam, - looks like a decent cam
head springs. - cam suggested to run with PAC1218s
do I need to pull the oil pan and look at the main bearings?
You'll probably be upgrading the pan for the swap. But as long as the crank turns nicely I wouldn't pull anything apart for inspection.
