Measured 7.400 PR's with milled heads??
So im assembling an lq9 for my truck, and got everything put together to the point where I can start measuring for pushrods. Cam is 228/234 cam motion custom cam, and a set of NGP 799 CNC heads, which I then had milled .020, and fresh ls7 lifters. So in my mind I'm already assuming I'd be in the 7.375 PR length, but I figured I'd measure anyway.
The first method I used was bolting the rocker down, and adjusting the checker to get zero lash, then adding .080 for preload. So at zero lash, I got roughly 7.300+.080=7.380.
I then tried the getting the other method of checking how many turns you get to 22ftlbs. I threw a stock ls3 pushrod in there I had laying around (7.400) and at zero lash, i got 1 3/4 give or take.
So I'm a little conflicted.. do I order 7.375s or 7.400s, I don't want a noisy valvetrain but I don't want too much pre load either
With LS7 lifters I believe the preload range is .070 to .1
What you want to do is measure till you get zero lash, then add your preload. In this case you got 7.380. Then take your checker and increase the size to 7.380. Install the rocker and by hand, turn the bolt. You'll hit a point where the bolt will stop spinning freely with just your fingers (what I did was put an extension on the socket and spin it by hand) at this point you've hit where the rocker will now start moving down and putting pre-load on the lifter.
Since you're aiming for .080, you'll want just a hair past a full revolution (figure each revolution is about .075). As long as you're within about 30 degrees of a full turn you're fine.
Not sure how you got that but don't think is correct. First turn will provide approximately 0.052", however using the adjustable pushrod with the valve springs will also change the numbers because there will be several thousandths compression of the pushrod due to the threaded section.
How easy is it too over shoot the base circle? I used the EO/IC method, so for example, checking the intake side, I would watch the intake valve fully open, close, then the exhaust valve would just start to open, and the rocker would move approximately 1/4" down (open) and that's when I would remove the intake rocker and start checking for that? And after that, I would let the exhaust open, close and just as the intake rocker begins to open, again approx 1/4" of travel, I then pull the exh rocker and check that length.
I just needed to type that out so I know I'm getting to the base circle correctly lol
With the turns method I think going to 22 ft/lbs will overshoot. You should just turn until the rocker is hand tight. After that the rocker is not moving down any more. With those round head bolts you get with after market rockers, for example, they compress down some into the hole slightly after the rocker has stopped moving but the torque wrench is still turning.
I got .048" on the bolt threads. Being very clear, I'm talking about the rocker bolt. The valve tip end is fixed, and the length ratio is 1.7:1. So, the distance traveled by the pushrod end is 2.7/1.7 or 1.58x further. I rounded down to .075
Considering the Johnson lifters I installed want .038 preload, which equates to half a turn of the rocker bolt, a full turn would then equal .076 would it not?
Per what Darth_V8r and Tony Mamo have told me:
