Cam Decoder Question
Old Oct 20, 2017 | 10:58 AM
SmokeyCheese1's Avatar
Default Cam Decoder Question
Looking at a cam. Seller claims in the ad the cam is a "custom grind" 224/236 .600/.600 113
Engraving on the end is 3722R/3728R HR113.0 U5778-10
Comp Cams Lobe Master Catalog says -
3722 - 224@.050 .581 lift @ 1.7 ratio
3728 - 236@.050 .602 lift @ 1.7 ratio
113 degree LSA no advance
The seller is sadly mistaken correct? Whats U5778-10? A serial?
Old Oct 20, 2017 | 12:53 PM
farmington's Avatar
close enough to not worry about it.
Old Oct 20, 2017 | 01:44 PM
stockA4's Avatar
That sounds like it would be a nice mild cam for a 408 in a heavy *** vehicle. Probably work pretty good with a blower on a 346 as well.
Old Oct 20, 2017 | 08:44 PM
JoeNova's Avatar
Restricted User
Do you mean mistaken as in mistaken about its specs or mistaken that its a custom grind?
It could still very well be a custom grind, seeing as how it shows a grind# and not a part #.
Old Oct 20, 2017 | 10:54 PM
The only thing mistaken is the lift #'s were rounded up AND down, maybe because he couldn't remember the correct ones? As said, close enough!
