Replacing DART225 heads worth it?
Hi Guys,
I have been on here before but my email has collapsed, no idea what my passwords are etc...
I have a TVR Cerbera (2600lbs) with a 416CI LS3 base, fully forged on Kinsler ITB's, but i am on DART 225 heads which i have opened the combustion Chamber up to match the 4.065 bore, plus a porting job and 5 angle valves, however these are the Standard 2.02/1.6 sizes.
I want to stay with Cathedral ports because i want to keep the ITB's.
Would i see gains if i went for Trickflow 245's for instance?
I am running a 244/256 cam, i would like to go a little milder on the cam as we pay 3 times what you do on gas!
It will run a 10.63/132 at the moment, 202mph verified top speed.
What are the considered cathedral heads these days???
Ive attached a pic of the car so you get the idea!
Brian Tooley hand finished Trickflow 245s. They seem to be getting faster and faster.....
Outstanding Machine!
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Location: Coast of San Mateo County Between Pacifica & HMB
Tony MamoMotorsport (MMS) 235s with NFI (Nitrous/Forced Induction)
Exhaust Port. With something like 239*/243* ~.650"/.630" ~114*+3*
For Cam Specs. Better Performance, Better driveability (smoother), little better economyWhen cruising,
tough to get better performance & economy from the same
CID & performance, but it is possible with Better Heads which allow
A more Optimized (smaller duration & smaller exhaust split) Cam.
Money no object LLSR Cam from Cam Motion slightly less duration
But more lift, 241*/245* (subtract ~6* for Lash & HR Equivalency,
~= 235/239) .690"/.670", make up the power with increased lift
& + 1000 RPM.
& + 1000 RPM.
Might as well go for good stuff. Mast 245 cathedrals. Flow 372 on a 4.065 bore plate. Gonna have a hard time beating that. Watch the flow Numbers there's a handful of companies that advertise flow numbers with a 4.125 or larger bore plate to make the heads look better than they are
https://www.mastmotorsports.com/products/ls1-245
Mast is a great head period. Expect to spend north of 4 grand on the Mast heads with all the gadgets. I just see more Tooley hand finished TFS 245s on motors because they're cheaper but it's plenty of guys running 4s in the 1/8 mile mile with Tooley heads and his customer service is top notch. Therefore I vote TFS
You must be special.
Closer to 2 HP (crankshaft) per 1 CFM.
300 CFM enough for 600 HP.
Gasoline potential could be as high as 2.2 HP per 1 CFM with
Optimal utilization (compression, rpm, cam timing and on and on)
I have a feeling that 2cfm per cylinder head flow is worth 1HP on the whole engine.
Example: The difference between a stock 243 head port and one with a Stage I TSP CNC port job is 53cfm PER PORT at .600 lift. That would equate to about 26 HP gain on that port job, with no other changes, on the WHOLE engine. TOTALLY makes sense.
Let's not overthink this...
Well that is the opposite of the way I put it, but your way makes sense once I did the math on a hypothetical case.
Thanks Hammer!
Thanks Hammer!
Yes I am a pretty special guy. If you ever visit Mast website and build you a set of heads using all the top notch components you'll see a MAJOR price difference between mast heads vs TFS done by Tooley. It's not hard to tie 4500 dollars into a set of mast heads Dan. And you always talking about Tony customer service is A1. I know that about Tony.. hard worker that barely sleeps but Tooley customer service is A1 as well and he even calls to make sure you get all your parts etc on time and all.
What I do know for a FACT about heads/porters?
I know every time I've visited LS fest I've seen a Trickflow 245 heads on different applications outperformed some heads that cost more money than TFS heads. Ask James Short who is one of the most respected tuners in the United States period what heads makes the most power on his stingy *** dyno and see what the answer be. He have dynoed EVERY LS head you can think of. And yet he is no salesman eithier.
