Putting new heads need advice
Old Nov 1, 2017 | 01:27 AM
5.3silveradoblue's Avatar
Default Putting new heads need advice
I am doing heads on my ls1 and want to know what head gasket to use and push rod.heads are 241 prc cut down to .30 and cam is a ms3 will I have to check valve clearance or I'll be good.thanks
Old Nov 1, 2017 | 01:33 AM
Do you mean milled .030"?
Cut down to .30 means nothing.
Old Nov 1, 2017 | 01:35 AM
Yes milled
Old Nov 1, 2017 | 10:23 AM
jimmyp3353's Avatar
I would most definitely check for PTV with that cam and milled heads, and measure for pushrod length.
Old Nov 1, 2017 | 12:02 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Unless you have the valves recessed or use a thicker gasket....
Old Nov 1, 2017 | 02:21 PM
black sky's Avatar
Very unlikely this combo will provide acceptable ptv measurements. Even with stock unmilled heads, the MS3'S PTV has only been described as adequate.
Old Nov 2, 2017 | 06:35 PM
So I'll have to measure to know the push rod length to.
whats the best gasket to use?
Old Nov 2, 2017 | 07:22 PM
Reg gm or thicker cometic if necessary
