Head gaskets......sry in advance
Old Nov 11, 2017 | 05:17 PM
Floorman279's Avatar
Default Head gaskets......sry in advance
When searching, you see a lot of milled heads, want more Compression etc. 2000 ls1 putting unmilled 799s on. I dont want a thinner gasket to increase compression, because i wanna reuse my 7.4 rods and dont wanna worry about ptv even tho i know ill be fine with my .605 cam. I want an MLS gasket. Do i just need any gasket that when torqued down is .051 and with a 3.91 bore? It dont matter weather i get gaskets for the notch or no notch heads right? Basically want a stock replacement GM gasket.
Old Nov 13, 2017 | 03:51 PM
farmington's Avatar
If it was mine ..... I'd assemble it with some used head gaskets and see exactly what I had for PTV. Then decide what you want to do.
Old Nov 13, 2017 | 04:09 PM
00pooterSS's Avatar
If you're talking about the early LS1 heads (perimeter bolt valve cover) that have the notch, you have to have the specific gaskets for those heads, ask me how I know.
Get a stock mls gasket.
Old Nov 13, 2017 | 04:46 PM
Spartan7's Avatar
So, use a GM gasket. When I pulled the heads on my completely stock truck to replace the lifters, I used replacement GM gaskets. They were actually cheaper than the Fel-Pro's at the time, which is what I usually use.
Old Nov 13, 2017 | 05:04 PM
00pooterSS's Avatar
https://www.texas-speed.com/p-209-gm...d-gaskets.aspx
Old Nov 13, 2017 | 07:50 PM
those are what i figured i needed. just wanted to double check that i n needed a .051 quench
Old Nov 14, 2017 | 05:22 PM
00pooterSS's Avatar
You want around .040 quench, that's optimal.
The pistons on your motor should come out of the hole on average around .007
With a .051 gasket and piston sticking up roughly .007 out of the hole, you get a .044 quench..... perfect!
Old Nov 14, 2017 | 08:30 PM
Yea I meant to say .051 gasket not quench.
