400rwhp
Old Nov 21, 2017 | 09:39 PM
  #41
Pompelen's Avatar
Originally Posted by Tuskyz28
Is your car manual or automatic? Eithier way this simple and easy combo will get you there. More power wouldve been made with a MORE DIALED IN CAM.
https://ls1tech.com/forums/dynamomet...hs-posted.html
I have a 4L60 Automatic transmission.
Thinking about a 3.36 gear ratio
Will need a new converter
Old Nov 21, 2017 | 09:43 PM
  #42
Darth_V8r's Avatar
Moderator
Youll get more out of the converter initially than the gear
Old Nov 22, 2017 | 08:39 AM
  #43
kinglt-1's Avatar
Tony Mamo made 480 whp with a 224/228 using his old AFR 205's and a ported Fast90. If you want to make good power and keep it civil, spend the money on good heads and intake with a mild cam.
Old Nov 22, 2017 | 08:49 AM
  #44
Bspeck82's Avatar
What was the control group? Need a baseline to see gains, otherwise peak numbers are useless.
Old Nov 22, 2017 | 09:15 AM
  #45
Felix C's Avatar
Lingenfelter himself always said similar. Much more fun for street driving as well. Heck you can use the very mild GT2-3 and ported heads, 241, 243, 5.3(add valves) and make 400rwhp. Quite a few GTO people have and the manners are impeccable. Has an OEM feel.
No dyno tricks as folks here post-uber light flywheel, no accessories, on the edge timing, open exhaust, hurricane wind ram air via exterior fan,etc.
Old Nov 22, 2017 | 10:43 AM
  #46
JoeNova's Avatar
Restricted User
Howards 226/232 112 LSA is kind of my go-to.
Old Nov 22, 2017 | 02:05 PM
  #47
allblackedout5's Avatar
Thats damn right. My old 227/235 112+3 was a tremendous street cam. I honestly thought it would make a great shelf grind. Pretty close to the titan 4. It made 470 open headers on mamo heads back in the earlier stages of my build. Damn near made 500 after other mods. It might have if it had been 114+2 instead of 112+3, but would have made less tq also.
Jakes recommendation is about as good a recommendation as youll get
Completely agree...I'm a bit above now with what I've changed since before, but my rwhp was 425 and rwtq was 409. On a verrrrry stingy dynomite and 92 degree humid day.... the power curve driving seemed to pull just as hard at 3000 as it did at 6000, just kept pulling..excellent street manners.
Old Nov 22, 2017 | 11:42 PM
  #48
kinglt-1's Avatar
His Vette trapped almost 125 in the 1/4 with that setup. How is that for control group?
Old Nov 23, 2017 | 07:10 AM
  #49
Tuskyz28's Avatar
The combo I posted earlier in this thread is a mild cam. 228R single pattern and the cam didn't have much lift at all vs some other cams on the market. The car put down 445 at the rear tires on a stingy mustang dyno with a aftrmarket stall.
If the 220 as cast TFS heads was combined with a custom cam from a mad scientist such as Pat G or Brian Tooley. I think 460 rwhp is at the finger tips with EASE threw a stall.... best part about the as cast tfs heads they deliver big numbers for less than alot of other aftermarket heads on the market.
Old Nov 23, 2017 | 09:22 AM
  #50
Darth_V8r's Avatar
Moderator
For 400 HP though, that is bolt ons and a moderate cam. Like fusion said. Something in the 227/233 range with 600-620 lift will be more than enough, assuming headers and a decent intake.
I agree, heads plus mild cam builds are way awesome. Op just does not need head work for his goals.
Old Nov 23, 2017 | 10:52 AM
  #51
Bspeck82's Avatar
Small cams and good heads is way more fun. Really can suprise people and you will take cam only cars lunch money.
Old Nov 30, 2017 | 12:11 PM
  #52
TrickFlowTech's Avatar
LS1Tech Sponsor
It's like I walked into an alternate universe where we have to take power away with all this small cam talk Yep, the EPS 226/234 in my old LS6 was great.
__________________
Old Nov 30, 2017 | 08:55 PM
  #53
ZeroTraction's Avatar
How do you guys feel about the new ws6stores high lift ASA cam. 226-236 .600" 110?
Also how about a reverse split cam like the old TR 230/224 .580s 111.....I read about guys making very good TQ with high HP with reverse split cams MTI x1 is another 230/227 .591 .571 112
Old Dec 1, 2017 | 03:18 AM
  #54
Darth_V8r's Avatar
Moderator
Reverse split cams are good for when your intake is more restrictive than your exhaust, such as the factory ls1 or ls2 intakes with long tube headers.
Usually, once you have upgraded your intake to a LS6 or fast intake, you do better with a traditional split.
Ws6store asa cam is a good mid-range cam. It will not run with the larger cams, but it is not intended to. It will easily support the 400 rwhp goal of the thread title.
Old Dec 1, 2017 | 09:10 AM
  #55
Bspeck82's Avatar
Lunati's 277/283 (113/109) might be worth considering as well. UDHarold designed them to specifically compete and beat comp XE lobes. He claimed he had a better overall design to pull more vacuum and make more power. For what its worth, the XE lobes from comp were his design as well.
  • Duration @ .050 (Int/Exh): 227/233
  • Gross Valve Lift (Int/Exh): .584"/.584"
  • LSA/ICL: 113/109
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 2200-6800
Old Dec 9, 2017 | 08:43 AM
  #56
Mart00SS's Avatar
Just for some sanity here. I have a 224/224 .563/.563 -112 decent chop at idle with 0* overlap, good torque throughout and good top end. ls6 intake, 1 3/4 long tubes and home ported 241's. Made 365whp on a mustang dyno. The key for you will be investing in good heads with a mid sized cam.
