Alum 5.3 or iron 6.0 sbe?
I have a 227/239 .614/.624 113+3 cam and basically 2 bottom ends to pick from. Alum 5.3 lm4 and iron 6.0. Going to use 243 heads. Should i be worried about valve to piston clearance with either? Id like to mill the 243s to bump compression up as well but brings even more concern about piston/valve clearance. What whp difference am i looking at between the two?
Moderator
Received 1,851 Likes
The 6.0 is a better match for the cam imo. Whichever bottom end you pick you will need to clay the pistons for ptv.
Old School Heavy
Moderator
I agree, it should be fine. And yes, you use the clay to measure PTV. if it is too close, then make plans to flycut.
