Cam for C5 Z06
#41
Not sure what it runs or makes I'm still breaking it in before the dyno tune. Just trying to figure an apples to apples comparison considering we have the same short block I just have have more h/c than you and if your shifting at 7 maybe I should too, we'll see. Once the car is ready I'll start dialing in tire, suspension and so on. I originally intended the car to be less drag race more street friendly but that is quickly changing got a tubular k, deleted the asr, heat and ac full poly mounts and once I start racing I'm sure I'll start trying to squeeze every last tenth out. long story short excluding our drivetrain differences I'm trying to figure out the formula to make what you make + h/c power. if you went same h/c as me wouldn't your setup clear 500 to the wheels quite easily?
Finding a good tuner is a bear. You probably should buy hpt
It should run really well. Most probably give me more credit than i deserve. These things go like stink with just a little bit of common sense.
#42
Its hard to say man. If you have good suporting mods it should easily make more power than me. Will it accelerate better?? Idk....there is stuff not necessarily power related that has something to do with that.
#43
No.....it's just been running changes. I never really set out for the car to perform as well as it does.
There used to be alot of pics on here of stuff i did. But after the photobucket fiasco that ruined alot of stuff for people.
