Cam for C5 Z06
Old Dec 4, 2017 | 09:39 AM
farmington's Avatar
Default Cam for C5 Z06
Looking to get a 04 Z06 in the spring (owner put it in storage for the winter).
It has a full exhaust and cold air intake and is crying for a camshaft. Looking for something thats around 228-230 duration and no more than .600 lift. Prefer something that is easier on the valvetrain too. Have a 224r in my Z28 and its been in there for 8 years now with 918 beehives. Prefer to use beehives on new camshaft too. I will probably be putting a ported FAST 92 and LS2 throttle body on at the same time. I'm not looking to get every last horsepower out of it, won't shift it past 6200-6500 rpm.
Anybody have any suggestions?
Old Dec 4, 2017 | 09:45 AM
HCI2000SS's Avatar
I used to really like my Torquer 2 cam. 598/595, 232/234 ,112. The specs are a nice all around compromise IMO
Old Dec 4, 2017 | 09:49 AM
kinglt-1's Avatar
the stock cam revs to 6800 in a ls6...you would be downgrading putting a cam in that revs lower. better off to do bolt-ons and a set of 1.8 rockers.
Old Dec 4, 2017 | 09:57 AM
big hammer's Avatar
Stock cam is easily good for 410-420 rwhp and 7000 rpm.
Old Dec 4, 2017 | 10:01 AM
farmington's Avatar
I know I don't want anything smaller than the 224r that I have in my Z28. the stock cam would be coming out for sure. Just because it can rev doesn't mean its making decent power up top
Old Dec 4, 2017 | 10:19 AM
A.R. Shale Targa's Avatar
Texas Speed offers a 228/232 @ .600" cam similar to the Ed Curtis Street Sweeper HT and the Cam Motion Titan IV
PSI max-life beehives are like top dog (1511)
Old Dec 4, 2017 | 10:24 AM
big hammer's Avatar
Peak power means less than average power over your used powerband
Old Dec 5, 2017 | 03:47 PM
ben42391's Avatar
tick performance sns3
Old Dec 5, 2017 | 08:22 PM
TXZ28LS1's Avatar
Running TSP 233/239 on 112.. easy drivable.. nice lope. Prolly the biggest i would run.
Old Dec 5, 2017 | 10:16 PM
HioSSilver's Avatar
Why does errybody think they need a cam?
King has a good idea. Results from that in the sig.
Hammer is right also.
Old Dec 6, 2017 | 07:57 AM
mjs1012's Avatar
Gotta love the idiots on here. OP is looking for something very mild and this guy says "hey I didn't read a single word the OP wrote, but here's a big donkey dick cam that sounds cool"
If you're really going to go with a cam, I can't recommend the streetsweeper HT enough. Loved that cam in my car, but you'd want to step up to a dual spring to run it because its slightly over .600 lift (228/232 .612/.600). Makes great all around power and drives nice.
Old Dec 6, 2017 | 08:04 AM
big hammer's Avatar
A good sleeper cam is the lingenfelter gt2-3. Sounds stock
Old Dec 6, 2017 | 09:31 AM
HioSSilver's Avatar
Btw op.....why only shift at 6200-6500? I shift my stock cammed ls6 at 6900 and i think it will like more as it used to crack the limiter @7k rpm with ease. It's at 7300 now.
Old Dec 6, 2017 | 09:40 AM
ddnspider's Avatar
Once upon a time I had that cam. It ran well and did sound really close to stock, but doing it over I would have gone larger and it would have made more power and drove just as good.
Old Dec 6, 2017 | 09:50 AM
Bspeck82's Avatar
Since you dont want to rev high id stick with a single pattern cam for more under the curve power. I would choose a cam with aggressive lobes, they will make more power and have a better idle/vacuum. Stock heads I wouldnt bother with more than .600 lift as you said. I would probably just get another 224/224 cam or if you want to sacrifice from the bottom and put a little up top a 228/228 or 230/230 cam. I wouldnt over think it, go call some of the cam guys and ask questions. Believe me, they like to talk about cams.
Old Dec 6, 2017 | 07:06 PM
98znasty's Avatar
Another vote for the 228/232
Old Dec 6, 2017 | 07:59 PM
farmington's Avatar
I really like the 224r in my Z28, and really wouldn't have a problem with buying another one or a 228r, its just been a while since I had looked into cams and wondered if there was any "new and improved" cams out now.
Old Dec 7, 2017 | 08:54 AM
98znasty's Avatar
It's funny, some people claim a bolt on ls6 will put down 400+ others will say a ls1 with cnc'd ls6 heads and a 22x/23× cam and a fast intake will only put down 410...
Old Dec 7, 2017 | 10:15 AM
Darth_V8r's Avatar
Moderator
it depends on the bolt ons list. Most guys do headers and an intake and call it bolt ons. Other guys also do EWP, vacuum pump, elec power steering, light clutch, etc. There is a solid 40+ HP difference between those two approaches.
It's all based on what you are thinking when you type "bolt ons"
Old Dec 7, 2017 | 10:42 AM
HioSSilver's Avatar
Nothing to claim about it. It's not even hard to get a ls6 over 400whp. See the sig. It was easy to get over 400whp with one. And it only makes sense. A ls1 will easily make in the 350-370whp range with bolt ons. My math tells me a ls6 is rated at 50-60 hp more. That puts a ls6 in the 400-420 range. Pretty easy to figure out. I had nothing special to go over 400whp the first time my ls6 was dyno'd. And from the looks of the et/mph you can't say the dyno was happy.
Hell I'm hoping to get near 450whp after these last changes.
The guys with the 410whp h/c cars clearly fucked up somewhere these days. They don't like hearing that because erryone wants to think their combo is some magical hp bullshit. But take a look at what op wants to do......wants a cam then don't want to shift over 6500 rpm. To be blunt that's a fucked up stupid dumbass motherfucking idea right from the beginning. No offense
Especially when he shpuld already be shifting higher than that.
