XFI Cam Question
Old Dec 12, 2017 | 02:28 PM
CattleAc's Avatar
Default XFI Cam Question
Anybody have any feedback on this Comp cam- XR275HR/54-426-11...
Have a chance to purchase this at a fairly reasonable price. May be using it in a flat top 5.3 or stock LQ4 6.0...
Appreciate any feedback on manners, lobes, idle?
Old Dec 12, 2017 | 02:38 PM
z-maro's Avatar
I'm no expert, but I would assume the manners would be fairly different depending on if you put it in a 5.3 or 6.0.
Old Dec 12, 2017 | 03:19 PM
CattleAc's Avatar
You are correct...I should have stated feedback from anyone that's ran it in anything.
Old Dec 12, 2017 | 06:43 PM
stp001's Avatar
I wouldn't go to the effort of putting any cam in that wasn't exactly what I want. Even if it was free.
Old Dec 14, 2017 | 12:27 AM
stockA4's Avatar
that's a great cam. I'm running the XR265HR/54-424-11 in my 4.8 LR4. It is cut on the same (high lift) lobes as the 275, but has less duration and overlap which is perfect for my little 4.8.
I'm running the bare minimum LS6 springs with mine and they seem to work just fine and I rev it to the moon! The valvetrain is just as quiet as stock. These are gentle lobes that work great for a daily driver.
the 275 will be fairly aggressive in a 5.3, a little tamer with more displacement if you go 6.0.
tuning is paramount with any cam upgrade. With good tuning this cam will idle and drive just fine.
Old Dec 14, 2017 | 12:42 AM
What's the duration @.050", lift, and LSA?
Old Dec 14, 2017 | 09:36 AM
CattleAc's Avatar
Thanks man...excellent feedback...exactly what I was looking for...
Let me look, I'll get back here with it.
Old Dec 14, 2017 | 10:56 AM
CattleAc's Avatar
Dur @ .050 In-222 Ex-224
LSA-112
Lift In-.566 Ex-.568
Old Dec 14, 2017 | 11:38 AM
I would bet TSP has a cam VERY similar to that BUT would be much easier on the valvetrain.
Old Dec 14, 2017 | 11:55 AM
CattleAc's Avatar
I don't have much in it, I got it in a "package" deal...I'll probably put it up for sale...
Old Dec 14, 2017 | 12:57 PM
stp001's Avatar
CattleAc, I am not a cam expert by any means, but this might just be the cam you are looking for. Especially if you have it.
Since you didn't mention the vehicles involved, just going by the motors mentioned, I will assume this is going in a truck. Since most trucks are automatics, this cam might be considered on the outer fringe of compatibility with OEM torque converters. The 5.3 more so than 6.0. This cam, while hardly a strip cam, has enough duration to be considered a performance cam as compared to a torque cam. With an advertised operating range maxing out at 6800, you must realize the torque you give up down low to have those capabilities. You would have to be the judge of whether or not you plan to play way up there. You can go to the Texas Speed website and see dyno graphs of different cams to see where you gain and lose power compared to your stock cam. It is fairly enlightening.
Once again, I will state that I am not a cam expert, but compared to the many cams offered today, that cam really doesn't seem to have very high lift, or harsh lobes. There are street cams available that produce .650 total lift with ramp rates under 50 degrees from .006-.050. This particular cam has .560 lift in 53 degrees of duration in same scenario. I understand there is more to lobe profile than those specifications, but that info isn't readily available.
To me, this cam would be ideal for a car with a standard tranny, or a car/street truck with a modern A4-A6 with a low first gear and something steeper than highway gears or a bit of a stall.
Old Dec 14, 2017 | 04:04 PM
CattleAc's Avatar
Thanks for the info stp001...Actually I have a 5.3L M6 3.73 gear in the wagon in my avatar...I'm running a the Z06/lS6 Vette cam now. It's better than a stock truck cam, but not that great...I may have to take a closer look at this new cam before I get rid of it...
EDIT: I have a forged flat top 6.0 on the stand waiting to go in. Maybe this would be a good cam to experiment with since it's gonna' almost be a freebie...???
Old Dec 14, 2017 | 04:09 PM
Good idea; more displacement makes any cam more forgiving as far as drivability.
Old Dec 14, 2017 | 11:14 PM
kinglt-1's Avatar
I have the HR- 277 224/228 112 in my LS6. Good cam, fairly mild lobe...mine is the low lift designed for higher ratio rockers. I went that route since I already had SLP 1.85 ratio stock style rockers. It pulls like a banshee to 7200 rpm with my ported 92 and TEA LS6 heads. Makes good power everywhere. Honestly does not feel like I gave up anything down low. Compression bump probably contributes to that.
That 222/224 should work great in a 5.3 and make good average power.
