Timing chain
Old Dec 17, 2017 | 10:41 AM
ovaboost's Avatar
Default Timing chain
Hello all im in the works of timing my motor and have got it timed with all new gm gears and a Katech c5r chain and now the problem is there is way too much slack on the chain has anyone had this problem and how did yall fix it built forged lq4 for with twin turbos...im about to throw this **** away and get a new timing set from cloyes. I also found other post but didnt help much
Old Dec 17, 2017 | 11:40 AM
Define "too much slack".
Old Dec 17, 2017 | 11:46 AM
z-maro's Avatar
Here is the slack that my stock one had with 62k miles:
I went with a Cloyes and a Trick Flow damper for some added insurance.
Old Dec 17, 2017 | 12:02 PM
pantera_efi's Avatar
Default Avon Gear Timing Set
Hi Ova, this is the common timing set used in a GN-West engine.
This is what I SELL/INSTALL.
You WILL find the requirement for the Cam Tunnel/Main Bore distance different between an AL/Iron Crankcase.
What is your crankcase material ?
The sprockets are steel with heat treat, the chain "oils" each link with a passageway, the links are much wider that the IwIs chain.
Lance
Attached Thumbnails Timing chain-dsc_0322.jpg   Timing chain-dsc_0323.jpg   Timing chain-dsc_0324.jpg
Old Dec 17, 2017 | 01:30 PM
ovaboost's Avatar
https://www.youtube.com/watch?v=9oQZ1_ZtPpk
the video you posted is the same amount of slack i have
Old Dec 17, 2017 | 03:08 PM
01ssreda4's Avatar
I just did a c5r chain (nice piece) that had about that much slack. Threw on a damper and gonna let it eat.
Old Dec 17, 2017 | 03:21 PM
As said, the aluminum block "grows" as it warms up, causing the chain to tighten up properly. Run it.
Old Dec 17, 2017 | 04:03 PM
ironmanLS1's Avatar
I tried an LS2 chain on a stock set of gears and didn't like as much slack as I had so I replaced with a complete Cloyes single chain and gearset. The Cloyes set fits nice and removed the slop I was uncomfortable with. My recommendation would be to move over to a complete Cloyes set. Pick your poison, single, double, hex-adjust.
Old Dec 17, 2017 | 04:05 PM
ironmanLS1's Avatar
That's part of the problem, too many people slap **** together and "run it".
Old Dec 17, 2017 | 04:27 PM
ovaboost's Avatar
I have an iron block lq4 not aluminum ls2.. i would hate to mess up my fully forged engine over a dumb *** loose chain for 150 dollar chain i figured this thing would be nice and tight what a joke.. even the old jp cheap chain i ran before hardly had any slack
For what i have in this c5r chain and gm gears i should went with cloyes kit
Old Dec 17, 2017 | 04:34 PM
01ssreda4's Avatar
Engine grows, needs some slack. Too tight and you wear your front cam bearing....ever looked at em, they are usually half trashed anyway. These motors have ALWAYS been this way, since 1997. Thats 20 years, so dont act all high and mighty. Its fine. Chain failures are not common in the LS world at all.
Old Dec 17, 2017 | 06:01 PM
Iron blocks, actually ANY blocks, grow too, just not as much. You'll be fine. The timing set you have will work, they are the same for almost all LS engines.
Old Dec 17, 2017 | 07:24 PM
Default Block Align Bore = Slack
Hi ALL, my BET is that "OVA" had his block Align Bored.
I have measured the Front Main "flex" by "prying" the crankshaft in the direction of the cam, you would be amazed.
Lance
Old Dec 17, 2017 | 08:28 PM
ovaboost's Avatar
Lance
it was all sqaured off and used bore and hone on torque plate and all the goodness of building a short block from what my engine builder said to prevent flex.... but it has just as much slack as the ls1 chain video posted above ill call katech see what they say
they may say i need a timing damper
Old Dec 18, 2017 | 06:55 AM
vettenuts's Avatar
Katech was recommending the Cloyes sprockets (gears if you will) and a damper last time I read some of their technical information (Jason is on this forum so you can send him a PM). I would definitely install the damper while its apart. I ran the Katech C5R chain and GM sprockets in my first setup. Also installed the GMPP damper. There was some slop but no issues. I have since upgraded to the IRL (rain) chain with the Cloyes Hex-adjust and damper. This setup is no longer available and SDPC bought the last sets from Cloyes several years ago. Not sure if they have any left but this was the ultimate timing setup for the LS motor.
Old Dec 18, 2017 | 11:36 AM
says the chest thumper.
He may be, but he is right about this.
Old Dec 21, 2017 | 10:51 AM
01ssreda4's Avatar
Hmmmm, I guess i missed his ninja editing skills.
