help with cam
ok i know this has been done a million times but I and new to this and would like some help with cam choice.
I have a stock short block ls1 with afr 215 heads with 0.040 compressed head gasket, pistons are 0.006 above deck which gives me 0.034 quince.
compression ratio is 10.7 , has comp cams adjustable timing set , 25 % under driven pulley set , stock rockers , 102mm fast intake with 100mm bbk throttle body . headers are 4 into one , primary pipes are 1 7/8 into a 3" chamber then reduces to 2 1/2" exhaust system.
160 thermostat / rear end is true track centre with 3.7 gear ratio with a 245/40/18 wheels. car weight is 3790 pounds. at this point I have a comp cam xr 265 hr which is making 387 hp at the wheels.
now I have good flowing head I would like a better cam to suit this set up.
has a 4l60 trans with a 2000 -2200 still .
it will also need to work with a 125 shot of nos.
any help would be great and thanks.
Our high lift hot cam would be a step up from that setup and would like nitrous quite a bit. Itll work with that stall no problem also.
Xr265hr is a 212/218. The high lift hot cam is a 218/227 .600/.600 112 lsa.
A cool research tool is the TSP website. They have dyno charts for a lot of there cams. Go to you tube for even more. You will even see where "torque" cams differ from "horsepower" cams. They are on a 5.3 though. You also should consider one of those cams. They offer shelf cams in a very logical sequence from mild to wild.
Another cool video about the Lunati 219/223 that swayed me was "the little cam that could". Google that and it will give you info on cams of varying durations.
I ship USPS with low customs duty.
I would spec, for your guess (a heavy foot NZ man), Crower Cams Grind :
232/246 .560"/.560" 116 C/L
I would do a DRY NOS
I could include the head studs.
Lance. BTW Bob Clarkson was a customer of mine (your Pri M in the past ?)
