C5R Valve Covers, Where to buy?
Old 07-20-2004, 01:23 PM
cfi_luz's Avatar
Everyone I know had to cut a set out of rubber gasket material for themselves, but it seems to hold fine.
Old 07-20-2004, 03:16 PM
KJ
KJ's Avatar
Ok, I looked in to this a little more. You do have to make your own gasket. Fel Pro & GM Performance have no listing at all for a C5R valve cover gasket. I would think it sould be easy to find material to make a gasket that will work....
Old 12-08-2005, 07:58 PM
aremfg's Avatar
Tall LS1 valve covers, with or without "oilers" available from ARE Dry Sump Systems- www.drysump.com
Old 12-09-2005, 07:22 AM
LS1TECH Sponsor
Katech_Jason's Avatar
Originally Posted by KJ@SDPC
I have them in stock for $215.00 per valve cover. I should be able to get the gaskets also. As for the coil pack relocator's I have some for the Katech covers that come with longer wires. I'm not sure how they would work with the C5R covers though.
They would only work if they have the holes drilled and tapped on the top side.
Now THESE are C5R CF valvecovers
Old 11-01-2006, 01:40 PM
96-speed's Avatar
Your exhaust port block off plate is a little nicer than my duct tape!
Quick Reply: C5R Valve Covers, Where to buy?
