eagle stroker kits
Old Oct 29, 2006 | 05:09 PM
Thule's Avatar
Default eagle stroker kits
what do you hafe to say about them? i was goin to buy a 383 kit, comprs 11.4,
all info are well acceptet,
thanks,
Old Oct 29, 2006 | 05:18 PM
Raben's Avatar
thanks,
Ive got the Eagle 408 Kevin Fisher does all my work and thats what he uses no complaints.
Old Oct 29, 2006 | 05:25 PM
Thule's Avatar
i was reading another thread here i someone talket about that the eagle kit need to be ballanced? can i not just install it and go driving?
Old Oct 29, 2006 | 05:40 PM
1BADAIR's Avatar
all rotating assemblies should be balanced
Old Oct 29, 2006 | 11:06 PM
Grimes's Avatar
From what I hear, the eagle kit requires a little more balancing than most kits. however many ppl have run them with no problems at all. As mentioned before, always balance your assembly.
Old Oct 29, 2006 | 11:18 PM
Raben's Avatar
Umm yeah its not just Eagle its all of them.
Old Oct 29, 2006 | 11:28 PM
Oh4GTO's Avatar
If I remember correctly the actual kit comes balanced from Eagle.
Old Oct 30, 2006 | 12:44 AM
8GTOKLR's Avatar
i contacted eagle a bit ago and they are still working on a 394ish stroker for the 3.9 bore.
Old Oct 30, 2006 | 01:51 AM
99camarosupersport's Avatar
^^ On the ls1 block?
Old Oct 30, 2006 | 08:08 AM
sroach20's Avatar
only if you buy the pre balanced kit. they sell balanced and unbalanced.
Old Oct 30, 2006 | 09:21 AM
8GTOKLR's Avatar
Yep on the LS1
Old Oct 30, 2006 | 09:31 AM
Wow i didn't think the Alum. block could take that.
Old Oct 30, 2006 | 11:05 AM
racer7088's Avatar
I sell and have used a couple hundred of these cranks and have never had any problems.
Old Oct 30, 2006 | 12:45 PM
rocketman442's Avatar
Cool any release date for the 394?
Old Oct 30, 2006 | 03:59 PM
8GTOKLR's Avatar
eaglerod.com. I sent them a email on the 28th of Sept.
Old Oct 31, 2006 | 11:25 AM
Thule's Avatar
i hafe bin searching the sponsors and i cant se if the eagle sets are ballanced or not,
when will the 394 kit come out and what will it cost?
Old Oct 31, 2006 | 11:53 AM
racer7088's Avatar
Thumbs up
They are not balanced unless you order them that way. It generally is 150.00 more.
Old Oct 31, 2006 | 01:38 PM
Thule's Avatar
my motor died month ago, so i nedd a stroker kit, seems to me like the eagle kits are the cheapest (that i trust)
any price's for the 394? should i wait for it?
anyone here that know both 393 and 383? saw that they are the same prize, will i fin d some diffirent in hp's
what is the best cam for those kits, want as much hp's as i can get in a car that is used most days..
with a good cam and stroker kit, is the fast 90/90 a good combo?
Old Oct 31, 2006 | 10:35 PM
Nemo02Z's Avatar
Im gonna add another question to the eagle stroker kit how high of a cam can you run with stock heads that have refurbished at what point do you run into problems........
Old Oct 31, 2006 | 10:36 PM
Bader-X's Avatar
how much for the current 383 balanced and not balanced? and what`s the material for the crant rods and pistons?
why nobody sells a kit with a crank with the same material as the stock crank (wich I read is pushed to 500-600 rwhp no problem) and a price of 1250-1500 Bucks
