Head decision for 5.3 NA build.
I have 862 heads, I can use but don't know if they're the best option. Are they worth getting ported for my purposes or are aftermarket casting the better option?
I'm also considering a 4.00 crank in the build so I want to make sure these will flow enough in ported form.
I'd like 4-500 rwhp. I think that will be enough power to keep me happy. I'd probably be happy with just a cam swap but why not go big.
Easily able to eclipse the 400 RWHP with the factory 325 cubic inches
They are CNC ported; flow nearly 300 CFM, and have the factory rocker arm compatible powdered metal valve guides.
414 with square port heads and your really going to scoot. 9.9x type deal
Building the car to cruise around in and occasionally take to shows, drive to the office, etc
I want nice street manners with a manual trans behind it. I want it to be slightly faster than the mustang(I know blasphemy) I had in college that was a full bolt on and tuned car.
Should be pretty easy to outperform it with the newer tech.
If you add 243/799 heads and a decent cam something like the 228r 112 you would run solid 12's
To take a 3400lb car to 11's with a 5.3 is going to cost you, a LOT. So why chase a number? Spend smart money on cubes if staying NA or boost the 5.3 and run 9's all day
cheap/fast/good pick two
So without a power goal we are talking money vs performance. I offered two options both RELIABLE as in factory reliable. LS9 cam, blue springs, stock everything else will have 12 second potential in his car with the 5.3. To build a 5.3L to go 11's in that car? Is cost prohibitive, so why waste money? Only fools do that. So its not an all or nothing perspective as in a save or waste perspective. Taking a 6.0L to a relatively easy 11 is possible but a 5.3 that is DD reliable is not so easy. There are some who got lucky and managed opver acheiving performance from 5.3 but thats more lotto luck and not the norm.
So why spend $1000's on heads worth 20-30hp on a basic 5.3 build? Total waste of dough imo.
Of course this is only advice, you can take it or leave it. Its the OP or anyone elses money and time who reads this. Best of it whatever route you choose
Clean up the heads with a little port job, new cam, headers, intake, and a tune. Should run just fine and be enjoyable.
almost every thread with good advice and someone goes on the attack and why? What in the damn HELL does anyone expect to gain from jumping all up in someone elses OPINION on an internet forum?
Offer your advice, let the people choose for themselves and get on with the pursuit of happiness already. Tearing up another member for their advice isn't doing anyone any good at all.
OP glad you have a plan and are chasing after it
