Head decision for 5.3 NA build.
Old Jan 13, 2018 | 01:13 AM
  #41
chrisfrost's Avatar
just an fyi stock 5.3 pistons are dished I believe 9cc's and the 4.8 pistons are flat-tops that have the same compression height and pin diameter and are sold in stock, .010, .020, .030, and .040" oversize
Old Jul 18, 2022 | 01:01 PM
  #42
Ls BO 53's Avatar
Originally Posted by 76firechicken
absolutely
I'm also considering a 4.00 crank in the build so I want to make sure these will flow enough in ported form.
I'd like 4-500 rwhp. I think that will be enough power to keep me happy. I'd probably be happy with just a cam swap but why not go big.
I really like 243 heads milled.and ported and then you pick a cam and typical Bolton should out you just shy of 400 whp. Unless your set on staying NA you could pick up a good complete turbo kit on budgetbuildinc.com including fuel system foe less than what a stroker kit will run you and you avoid opening up your engine. One should always avoid opening up the engine if not a must. For less money you.could have a 700whp build. Or there's a vortech v3si centrifugal blower foe about 3k
Old Jul 18, 2022 | 01:49 PM
  #43
98% of everyone here know what you said above.
Just trying to build post count?
