GM head gasket reusable?
Old Jan 14, 2018 | 01:16 AM
98Bluebirdls1's Avatar
Default GM head gasket reusable?
Can gm head gaskets be reused after torquing the heads ? I ran a cylinder leakdown test amd the heads were no good, so i took the heads off. the engine has not ever been fired yet. is it a good idea to replace the gaskets or just use them since there are no wear on them? Thanks!
Old Jan 14, 2018 | 04:24 AM
Buryingthesun's Avatar
Im sure some cheap scumbag has reused them, I would never reuse a head gasket.
Old Jan 14, 2018 | 07:32 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I believe Denmah/Sloppy Mechanics has done this with great success. But, that is a small sample size.
Old Jan 14, 2018 | 07:44 AM
Mart00SS's Avatar
The answer is probably but Hell no. This is one item that makes no sense to re-use. The risk will always outweigh the gain (which is only the cost of the gasket).
Old Jan 14, 2018 | 08:10 AM
unit's Avatar
The answer to your questions is yes, mls gaskets can be reused. That said - if you consider the amount of work involved to remove the head and prepare it for reassembly, I'd say it would be best to use new gaskets. You probably won't want to do it again if the old gaskets don't seal.
Old Jan 14, 2018 | 08:20 AM
01ssreda4's Avatar
MLS can be reused yes. Does that mean I would chance it? Probably not.
Old Jan 14, 2018 | 08:28 AM
KCS's Avatar
KCS
Moderator
Stock MLS gaskets, and probably most of the aftermarket gaskets, are fine to reuse, especially if it hasn't gotten hot yet. Just be sure to clean it before you reinstall it.
Old Jan 14, 2018 | 05:03 PM
code4's Avatar
I have reused them a few times w/o any trouble. Didn't know it made me scum though. Ha ha
