2 pistons with cracked ringlands post mortem
I did a freshen up 6k ago replacing bearings and rings along with getting the block honed, crank polished and the block cleaned. I tore down because I had no compression and could hold no pressure on cylinder leakdown in piston 7. However on piston 3 compression was down to 150psi versus 180 on the rest of the cylinders.
I discovered that I trashed the ringlands on piston 7 and had a crack on piston 3 ringland. There was no pitting on the cylinder tops or in the heads of the combustion chamber.
Major mistake I know I made was not gapping the rings for boost and going with stock gaps. Would that alone have been the cause or should I be looking at other issues? I had a 6100rpm fuel cutoff trigger in place because I was out of fuel on the dyno beyond and was starting to go lean. The failure occurred during last winter when temps were cool. Thanks in advance for schooling a newb.
I just went through a 383ci LT1 a buddy bought from a guy on Facebook. The builder didn't bother to gap the rings either and the top and second rings were at about .010" out of the box.
But I have bent rods and spun rod bearings after a while.
I always open rings gaps. I usually run .28 and .30
Should have called sealed performance and told them I was running boost and got their tolerances. Should have made sure the ring gaps were uniform. I literally took the rings out of the box, found they met the spec I found and called it good without feeling the need to make them uniform or increase the gap. I at least staggered them just overlooked how critical gapping them was, pretty inexplicable looking back now.
On piston #3 that has a cracked ring land I ran .011 on top ring and .018 on the bottom ring.
On piston #7 it had .0145 on top ring and .0175 on the second ring. Here are pictures of piston #7 and #3 for reference and my sheet where I recorded gaps.
On the positive side I found a local that has a gen 4 L33 long block in good shape with 122k on it. It allegedly was pulled because of a failed lifter. I'm going to trade my lq4 bare block with no crank just mains and pistons for his short block including covers and sensors + 400$.
Will then disassemble the shortblock, and replace bearings and rings, get the crank polished, cylinders hone and block cleaned and decked. Then get my 243 ported heads decked and cleaned as well, I have a set of 317 heads sitting my garage that are filthy and may not be in good condition. Could get them checked and cleaned, swap my valve train over to it. More thoughts on next steps or previous failure? Thanks guys.
I talked to the owner again of the gen 4 block I'm looking at he said the lifter bores are good and he will be pulling the heads for me to look at them. It sounds like all is needed is for me to take my ls7 lifters and existing cam/cam gear and swap it over in addition to picking up an ls2 valley plate or tapping the holes and blocking them with a screw and loctite.
From a machine shop perspective if I pick up this block and the internals look good. I was going to replace rings and bearings and get the following done...
polish crank
hone cylinders
clean block
clean heads
deck heads/block
Should I balance the crank? Are rods bolts and main studs over kill? I don't ever plan on running more than 650whp on this block.
were ARP rod bolts and they opened up the already worn factory rings.
There's a funny reason why this "JUNK" was able to make over five per cube
I would not tear yours down, polish the crank, or hone the cylinders
Remove the pistons and rods, open the compression ring gaps to .028" primary and .032" secondary......re-install and use........freshly honing the block will only loosen the piston to wall clearance which will promote ring flutter and bleed off the compression you're trying to keep on the north side of the piston
Putting new moly faced rings in is also a bad idea as the boost can easily overheat the moly facing causing it to flake off and weld to the cylinder walls.......then it wreaks havoc on the skirts and everything
Also while the rods are out, get new ARP bolts, wire wheel the black oxide coating off the threads, apply the special lube, install with EPL under the bolt shoulder, torque and have the big ends measured. most times the machine shop can just stroke them on the Sunnen hone a few passes and they'll size right in....I'd just leave the crank right in the block
Sounds like you know exactly why it failed
