Lq9 cam?
Old Jan 16, 2018 | 01:11 PM
Eiyse98ls1's Avatar
Default Lq9 cam?
Have another thread in the external section but figured this question would be better in this section.
So I had an issue with cam code coming up swapped cam sensors, checked wiring. Car started to have issue with no start only crank which got worse to the point it wouldn't start. So at this point figured I have to check cam bolts. Buddy came over and pulled the cover and found all 3 cam bolts backed out. Upon going to retighten the cam bolts noticed no dowel/ pin going through sprocket and/or cam. Did it fall out from the sprocket being loose or did some stock cams did not have this pin/ dowel? Thanks
Old Jan 16, 2018 | 01:16 PM
As said in the other thread, you need the dowel pin. Yours fell out when the bolts backed out. You WILL need to find it, as it's in your engine somewhere, likely in the bottom of the pan.
Old Jan 16, 2018 | 01:18 PM
Eiyse98ls1's Avatar
Thanks for the quick reply. Definitely will tell buddy pan has to come off. Maybe also cam swap!!
Old Jan 22, 2018 | 09:39 PM
rpturbo's Avatar
Yikes!!!!!
Old Jan 23, 2018 | 12:05 AM
1FastBrick's Avatar
It's possible the dowel got pushed back into the cam. Either way you need to look for it.
You should be able to get a new one at the hardware store. I believe it was just a 1/4 dowel either 3/4 or 7/8 length will do.
Old Feb 5, 2018 | 05:48 PM
Eiyse98ls1's Avatar
Found the cam pin on magnet of drain plug. Should I run without it or just pull cam and swap it out for turbo cam at the same time change oil pump, chain.
Old Feb 5, 2018 | 06:08 PM
You MUST run a pin.
Old Feb 5, 2018 | 07:03 PM
Eiyse98ls1's Avatar
Ok. Guess gots to order a cam, etc
Old Jul 20, 2018 | 10:54 AM
Eiyse98ls1's Avatar
Update. Got the car back running with a new cam, oil pump , ls2 chain cam sprocket, refs chain dampener, oil pump girdle. Just waiting to here back from tuner for retune.. made sure to use red thread lock on the cam bolts also!!!
