What heads to run with EPS 222/226 113lsa cam
OP I understand what you are asking although I think that cam will work with any LS1/2/6 head. Ported or stock. The heads that would be a better choice would be those with better mid/low lift flow nos. and those flow nos. approaching peak lift. Then there is the intake manifold to consider, then the exhaust, then valvetrain, intake before the manifold, then drivetrain.
