Ticking , clacking noise from engine
Old Jan 31, 2018 | 02:50 PM
LOVEYESHUA's Avatar
Default Ticking , clacking noise from engine
When car is col it urns in and stay on only when my foot is depressed on the gas pedal. Also clacking noise when at stop, reverse and drive not neutral and park. Could it ne bent push rod, injectors or lifter? When at stop sign i could put the car in neutral rpm raise and noise is less noticable
Old Jan 31, 2018 | 02:57 PM
ss.slp.ls1's Avatar
Are you saying that you only hear the noise when in reverse and drive and you do not hear the noise in neutral or park? If so that sounds like an issue related to your transmission and not your engine.
Old Jan 31, 2018 | 03:11 PM
LOVEYESHUA's Avatar
Would i have to have it dissembled and redone. Just had it done about 5 months ago and yes, I hear the noise in reverse and drive, But when the car warms up its less noticeable and it also have not problems starting. just in the morning the start and stall issue
Old Jan 31, 2018 | 04:36 PM
HappySalesman's Avatar
Stock motor? Cammed? If so, how big of a cam?
How loud is the clacking? How many miles on the motor? Could just be worn out lifters bleeding down causing valvetrain noise.
Old Jan 31, 2018 | 04:52 PM
LOVEYESHUA's Avatar
Thumbs up
its not really loud, but very annoying
364,00 miles no check engine light issues, transmission goes into gear fine, just the cold start issue and clacking noise.
I looked on you tube it suggested the same thing you said, lifters causing valvetrain noise. Thank you for responding,
Old Jan 31, 2018 | 05:09 PM
garygnu's Avatar
cold start issue mite be a leaky injector .the noise you hear mite be wore out rocker arms .maybe remove the valve covers and inspect the rockers and push rods .push down on the push rod to check out the lifters .consider a thicker oil .
