Low oil pressure
Old Feb 3, 2018 | 02:10 PM
Andrewhuffman's Avatar
Default Low oil pressure
Recently noticed my oil pressure getting lower. Seem 20-25 Cold. It will hit 60 cold under high revs.
when it gets hot its like 5-10 psi.
been like this for a few weeks
ive replaced the oil pick up o ring, oil pump, pressure switch and aftermarket gauge.
whats next? Where does the oil go between the pump and pressure switch?
Old Feb 3, 2018 | 02:52 PM
computerz's Avatar
Since you already replaced the usual suspects, unfortunately that usually means things like worn cam bearings, rod and main bearings.
Sometimes the cam retainer gasket, or the (early design) barbell can bleed off pressure too.
Old Feb 3, 2018 | 03:22 PM
Been driving it for 2 years. Its got 255k on it.
2002, 6.0 Silverado.
would it be worth doing the cam cover or just rebuild engine?
Old Feb 3, 2018 | 03:42 PM
Gooze_1's Avatar
With that many miles I would just rebuild
Old Feb 3, 2018 | 04:31 PM
^^^^^This. It has lived a good life!
Old Feb 3, 2018 | 09:07 PM
Rings
bearings
gasket kit
valve job?
lifters
what else do I need to order for a full rebuild.
thinking a cam for towing.
hedders?
bigger tb?
Old Feb 3, 2018 | 10:04 PM
Ya know what? Call WS6store and see how good a deal they can do ya on a kit. They have really good deals on the stuff you need, AND the will customize a kit to what you EXACTLY need.
Old Feb 4, 2018 | 12:02 PM
cookseyb's Avatar
What he said...
Old Feb 4, 2018 | 03:03 PM
Originally Posted by cookseyb
What he said...
put the new cam plate cover on. Still low. I want to know for sure what the issue Is before I rebuild it.
Old Feb 4, 2018 | 03:32 PM
moekluse's Avatar
Yep that's average pressure for 250,xxx+ miles haha. Cylinders are finally worn down now so boost or spray the **** out of it and not worry about ring gap haha
Old Feb 4, 2018 | 08:02 PM
The engine is worn out. THAT is the issue.
Old Feb 5, 2018 | 06:35 AM
how long do you think it will continue to run?
Old Feb 5, 2018 | 10:25 AM
He's yanking your chain. Spray or boost it, and watch it blow, SOON!
Old Feb 5, 2018 | 03:52 PM
moekluse's Avatar
sushhhhhhh lol
Old Feb 5, 2018 | 10:48 PM
sushhhhhhh lol
warning light came on today. Tomrrow might be the day
Old Feb 5, 2018 | 11:09 PM
jetech's Avatar
Veteran: Air Force
Band Aid...shim the pump
Old Feb 6, 2018 | 02:37 AM
sjsingle1's Avatar
the cam plate gasket on my engine was basically gone when I tore it down......so I think for the price of a new plate its beats a rebuild anyday
a new oil pump would not hurt either....
Old Feb 6, 2018 | 06:48 AM
tried all that
Old Feb 6, 2018 | 08:23 AM
computerz's Avatar
Time for a teardown?
btw, if this has only been an issue for a few weeks, did anything happen just prior to that? Did it run low on oil for example?
Old Feb 6, 2018 | 08:39 AM
nope. Never skipped a beat
