Difference in 2001 to 2007 5.3
Old Feb 5, 2018 | 02:54 PM
Nashty's Avatar
Default Difference in 2001 to 2007 5.3
I have a J code (DOD) 5.3 that I want to replace with a new motor. I have a 2001 5.3, can I use that short block?
The reluctor wheel is different correct?
Can I replace the reluctor wheel and use the 2001 crank?
The DOD has been disable on my engine. It's a MAF tuned 2007 NBS Sierra with a mild turbo kit.
Thanks,
Roger
Old Feb 5, 2018 | 04:08 PM
01ssreda4's Avatar
07 could go either way on the reluctor. You cant base it solely on the year, you need to check if its a gen3 or gen4 motor.
