806 heads vs 862 heads
Old Feb 8, 2018 | 01:53 PM
redslut's Avatar
Default 806 heads vs 862 heads
I'm having a dilemma about what heads I should run on my car the setup is a tsunami cam and a Holley sniper long runner intake with a 102 tb, I'm worried that the 862 will kill power cause the small intake valve, but will the small chamber of the 862 compensate for the power or should I just put the 806 heads on it.
Old Feb 8, 2018 | 01:55 PM
HCI2000SS's Avatar
Are we comparing stock to stock here?
Old Feb 8, 2018 | 02:07 PM
redslut's Avatar
Yes stock to stock
Old Feb 8, 2018 | 02:20 PM
HCI2000SS's Avatar
Stock to stock it's gonna be close. The 862 head will obviously bump compression, but the 806 head will flow slightly better. I would think with that intake and cam you have the increased compression would be more suitable than the very slight increase flow of the 806 head
Old Feb 8, 2018 | 02:28 PM
redslut's Avatar
That's what I am thinking
Old Feb 8, 2018 | 02:31 PM
HCI2000SS's Avatar
What heads are in there now?
Old Feb 8, 2018 | 02:40 PM
redslut's Avatar
862 I have the motor apart rebuilding it and I have fresh 806 heads on the shelf
Old Feb 8, 2018 | 02:46 PM
HCI2000SS's Avatar
I see. If it were me i'd have those 862's worked over. I have PRC 5.3 heads (862 casting) and for the money I think they do really well. Either way since the heads are not on the car you might as well have them ported. That's just my opinion
Old Feb 8, 2018 | 02:57 PM
omc8's Avatar
well if you have the heads off now is the time to upgrade or improve them such as valves, larger or aftermarket, porting ,valve job . If your leaving stock because of budget .maybe porting isn't in the budget, at least a valve job and milling. 806 would not be my first choice but if your ok with perimeter bolt , go for it. Id probably go with 862 but with a port and slight larger valve.
Old Feb 8, 2018 | 03:36 PM
redslut's Avatar
It's definitely a budget lol
Old Jun 22, 2018 | 11:53 PM
Tbuckmaster's Avatar
ill tell you for sure they are a breeze to port and you wont be sorry
Old Jun 23, 2018 | 12:15 PM
cookseyb's Avatar
They are easy to port and my machinist installed 2' intake and 1.5 exhaust, milled .010 to insure flatness, new seals and I put 1218 springs on them for about 400 bucks out the door..
Old Jun 23, 2018 | 01:20 PM
omc8's Avatar
The 2" intake valve is okay, but not sure why you would want to go down in size on the exhaust side . 862 casting already has 1.55 exhaust. 806 casting is perimeter bolt and different coils and brackets. Go with the 862 a good valve job ,bowl blend and maybe valve upgrade combo 1.95 in and 1.57 ex
Old Jun 23, 2018 | 06:44 PM
cookseyb's Avatar
Fat fingered, the valves are 1.57, sorry for the confusion..
