Trickflow 220 valve guides
Old Feb 11, 2018 | 07:09 PM
Dalton Barrett's Avatar
Default Trickflow 220 valve guides
I’m getting ready to finish up my ls1 build and order my heads, I was wondering if anyone here has run stock rockers on the trickflow 220 as cast heads for an extensive period? This won’t be my daily driver but it will be street driven often and I want to make sure the valve guides won’t prematurely wear. If it comes down to it I’ll just buy a set of roller rockers, but if the stock rockers will work just as good I’d like to keep them, as I’ve already got the trunnion kit installed.
Old Feb 11, 2018 | 07:45 PM
Are the valve guides bronze or iron? Bronze almost demands roller rockers as they don't like the side loads stock rockers put on valves.
Old Feb 11, 2018 | 07:56 PM
[QUOTE=G Atsma;19831815]Are the valve guides bronze or iron? Bronze almost demands roller rockers as they don't like the side loads stock rockers put on valves.[/QUOTE
Theyre steel. Will the side load wear the steel ones quickly or will they handle it?
Old Feb 11, 2018 | 08:24 PM
Basically same guides found in all GM LS castings. Pretty resilient guides.
I’d have to believe that there are many people here running these heads with Oem rockers without issue.
Old Feb 11, 2018 | 08:42 PM
2002BLKWS6's Avatar
I run the TFS AS Cast 220's with the powdered metal guides and I have the CHE Trunion upgrade. I dont daily drive the car, but with several thousand miles i've had no problems.
See post 9 in this thread by Brian Tooley which is a good read.
https://ls1tech.com/forums/dynamomet...l#post13879292
Taken from that same post in the next to last paragraph he says:
"The TFS heads come with springs that check at 160 seat 450 open. If you attempt to run stock rockers you need to install powdered metal guides to eliminate the guide wear, and install springs that are no more than 400 open, like the "platinum" springs that TEA sells, they check at 160 seat 400 open. This lesser open pressure makes life easier on the valve tips."
A bunch of folks run the metal guides and stock rockers and are fine.
Old Feb 12, 2018 | 06:58 AM
Choppy_Idle's Avatar
^^^ This is nearly the same, M.Smallwood told me these days, extreme lobes with solid rocker needs powdered guides in a long term condition...
Greetz
Ron
Old Feb 12, 2018 | 07:41 AM
vettenuts's Avatar
It will depend on your cam lift. I would also upgrade to a larger OD pushrod to eliminate valve bounce. I would definitely get the steel guides, given the option.
Old Feb 12, 2018 | 10:26 AM
bbond105's Avatar
This explains why my valve tips were chewed up. Stock rockers with metal guides.
Old Feb 12, 2018 | 11:01 AM
You have to clarify when you say "metal" guides. Bronze and iron are BOTH metals!
Old Feb 12, 2018 | 11:24 AM
A.R. Shale Targa's Avatar
Could also be some "wet noodle" push rods causing high RPM deflection which leads to rocker tips "scrubbing"
You are correct; most refer to them as powdered metal..
Old Feb 12, 2018 | 12:14 PM
There ya go!
Old Feb 12, 2018 | 01:00 PM
bbond105's Avatar
Powdered metal guides with 11/32 push rods. As Brian Tooley says in the link when the stock rockers are shimmed the 220's open spring pressure is too much and the valve tips suffer as was the case with my previous set up.
Old Feb 13, 2018 | 11:20 AM
pantera_efi's Avatar
Default Valve Guide Material = Steel
Hi All, I fit a German made Steel Guide #C3053H.
This guide is Induction Hardened.
The O.D. is .500" with .502" on request.
Lance
