Whats a good compression ratio?
#317 heads
going to 6.125 rods
standard stroke
#317 heads
going to 6.125 rods
standard stroke
Keeping static and dynamic compression low allows you to maximize use of boost.
Here's a simple formula to calculate compression under boost:
14.7 / SCR (or DCR) + 1 * boost PSI
It gives you an idea on how to set up the motor.
I'm N/A at 11.8:1, DCR is 8.2:1, still on 93.
Without water/meth, I would try to stick to around 9.5:1. With water/meth I try to stay up towards 10:1.
Like others said, Keep the compression down down to 9.5 - 9.8 for decent boost pressure.
I'm stuck with 91 octane here in Northern NV. I have to run no more than 12 psi on an A2A intercooler without Meth. 408, Martin turbo cam and TSP 2.5 317's with 9.6:1 CR.
Once I get a GOOD reliable Meth system, I'll be turning it up to the 18-20 psi range to see how things are looking.
Just keep an eye on your IAT, knock etc... and inch it up little by little
SCR (or DCR) / 14.7 + 1 * boost PSI
Sorry about that. Had a brain fart lol.
Example:
9.5 (SCR) / 14.7 = .646
.646 + 1 = 1.646 * 15psi = 24.7:1 SCR.
