Horsepower seems to be down.
And pair that with the long runner factory intake/TBSS or even an LS6 will fully support your 400 horsepower desire.
I’m thinking you’ll gain 40-45 RWHP and turn 12.60 quarter Miles
I think it is beautiful. I can't tell how much smoothing is in it, but it looks exactly what you want to see. That engine is running well. 2500 to 6500 is great for a truck, you can't do much better cylinder fill consistency wise.
It may have a tiny bit more power in it if you spun it higher, but I think what you are really looking for at this point is global constants. I.e. compression ratio, fuel quality, intake air temperature, exhaust or intake flow potential to raise that entire curve up a notch. I don't see the cam as a problem because torque is still very flat near redline. I don't see the head or intake as an issue because torque is still very flat near redline. If the head, intake, or cam, were a problem to overall flow, torque would taper off near redline like factory does.
Lets re-evaluate from another perspective so you can get a feel for what info is in that graph. If you notice torque stays mostly flat. that means cylinder fill is fairly consistent through all rpms. It even has that slight peak region right in the center which kinda says "yeah I am degree'd properly too and this is my 101% VE region" It means that all of the parts are working together very nice to give nice full cylinders at each RPM. We don't know how full; if they are, say, 85% full, you have room for 15% improvement in Flow. This would come from exhaust or intake flow mods normally, but in your case I wouldn't mess with anything. 1 because it runs absolutely perfect and 2 because you might already be near 95%-100% full. Compare the torque with other engines of the same size and compression and transmission to get an idea of how full the cylinders are next if you can. If you find another couple engines with the same compression ratio and trans making 50+ more torque than you are then we start looking for a global variable as a cause. It wouldn't be say, a restriction, because restrictions to overall max flow in mass/time units do not limit peak torque, they only limit peak power. A restriction to flow would therefore show up as a high peak torque and a fast taper down- which yours does NOT do. It could be say, a cam phase issue or overlap related, limiting cylinder fill. You might pick up 50+ ft*lbs of torque if you advanced that cam 5* or something silly because it is off somehow with respect to its position. tell me you degree'd it?
also it may be time to look at the cam card and see when the valves are opening. i no comp has probably done a lot of ls testing, but id personally go with a company who spends most of there time on the ls platform. comp makes cams for everything so how do we know they sat for hours and hours making tweaks and seeing how it affects things. cammotion, tsp, btr, all companies that spend a lot of time around these motors. when i contacted cammotion about swapping out my cam, they saw a lot of improvements i could gain just buy bringing on the intake valve a little earlier compared to my current cam. food for thought, ur comp grind valve events could possibly be better. now that i think of it, ive personally never seen any builds that make super good power using a comp specd cam, then again u don't see a whole lot on here anyway
Right now you have a LOT of area under the curve. Torque might be low but you will find and fix the global cause. Swapping the cam for more power upstairs would ruin the area under the curve, specifically the 2500rpm cylinder fill region, in exchange for more peak power on the dyno graph, which you would barely ever see or use on the street in a heavy truck.
