Horsepower seems to be down.
Old Mar 8, 2018 | 09:42 AM
  #41
JoeNova's Avatar
Restricted User
1. TBSS/NBSS intake makes more torque AND peak power than the LS6. Dyno tests have confirmed this.
2. That looks like a Mid-rise and not the Hi-ram.
Old Mar 8, 2018 | 09:43 AM
  #42
88bluchevy's Avatar
Reason for cam choice was i called comp cam and that was the cam they recommended. But after looking for a few days now I’m liking the torquer v2 from Texas speed. Seems a lot of people have good luck with it
Old Mar 8, 2018 | 09:47 AM
  #43
JoeNova's Avatar
Restricted User
Nothing wrong with the cam you have. I have one of those put back for a future project.
Old Mar 8, 2018 | 09:53 AM
  #44
KCS's Avatar
KCS
Moderator
Originally Posted by 88bluchevy
Tuner done leak down test and found no issues with that. As far as spinning the motor, I’m really comfortable with spinning it to 6400-6600 rpms. The cylinder heads are Texas speed prc 2.5 5.3 heads with 58cc. I chose that to try and bump compression up to. In my opinion this should’ve been a 500+ motor at the flywheel but the dyno is showing it to be 450-475.
Agreed. The torque is really low; you're making about as much torque as a bone stock LS1. That is usually a sign of something wrong in my experience, like a broken plug wire or cracked plug. I've seen a plug and wire change pick up 50ft-lbs of torque lol.
Old Mar 8, 2018 | 10:04 AM
  #45
88bluchevy's Avatar
Agreed on the torque being so low. It did have a problem before with plug wires being on header but bought msd wires that stick out past the headers fixed that problem. I’m really just baffled at this point. I thought head, cam, intake 6.0 would make good power but it’s making power as just a cammed 5.3.
Old Mar 8, 2018 | 10:13 AM
  #46
84c10's Avatar
I've never seen more than 5-8hp and tq difference between the two intakes if he has the mid rise that will be some of his lower peak power number problem, I'm not sure what makes you think it is by his picture posted, I cant tell. the tq number are down due to the intake, if you want a better tq curve take the high ram off and trade for a nnbs but be ready for peak hp numbers to go down. he needs to decide what's more important peak numbers or power under the curve.
Old Mar 8, 2018 | 10:20 AM
  #47
Floorman279's Avatar
there was an under the hood pic earlier
Old Mar 8, 2018 | 10:29 AM
  #48
88bluchevy's Avatar
The intake i have is a hi ram. I really want this truck to make great power considering it’s not just stock 6.0 with a cam and the power it’s putting down is replicating that. I do know the intake is killing down low but from 4500 and above it should be outshining the nnbs intake. I’m just trying to find the missing puzzle piece here as to why this combo didn’t lay down 400 or more to the tire when I’ve seen very similar combos lay down that or more.
Old Mar 8, 2018 | 10:37 AM
  #49
JoeNova's Avatar
Restricted User
Injector duty cycle?
You're not turning enough RPM to see any gains with that Hi-ram anyway.
Old Mar 8, 2018 | 11:15 AM
  #50
84c10's Avatar
compared to What? You don't need high rpm for the high ram to make good numbers.
Old Mar 8, 2018 | 12:34 PM
  #51
true but you do need hi rpms to make the loss of tq down low worth it. is it worth losing 25-35 tq from 1500-4500 for the 15-20 that you only see from 5500 to his 6300-6400 shift point? if he was spinning to a 7200 shift point then yea the 35-40 hp may be worth the trade. only the op can decide. its his build. just for *****, id let it gofer now and find a dyno day in your area this spring and try a different dyno out. hopefully a dynojet.
Old Mar 8, 2018 | 12:38 PM
  #52
one thought, how inefficient is a truck driveline vs a 4th gen? i know not 50 hp worth but maybe its a combo of a bunch of little things adding up to it all......maybe exhaust is 10, inefficient truck driveline and big tires 10, cam choice 10......not saying these are issues, just thoughts.
Old Mar 8, 2018 | 12:51 PM
  #53
JoeNova's Avatar
Restricted User
In the hot rod intake test, the high ram didn't make any more power than the NNBS/TBSS until about 6200-6300 RPM. He's only turning 6400.
Seems like a waste giving 6200 RPM worth of losses for a 100-200 RPM gain.
Should he have made more peak? Yes, but it also makes me wonder If there aren't other things in the combination holding power back. Like wrong pushrod length, bad cam timing, dead cylinder from bad plug/wire, etc.
Btw, my experience with high stall yank converters on the dyno has always been lower numbers.
Old Mar 8, 2018 | 01:42 PM
  #54
wph351's Avatar
My 200,000 mile 5.7 put down 390 hp 370? Tq on the base tune prior to breaking on the dyno. Sbe 5.7 home ported 243s 224 cam yank 3600 unlocked. Something is askew with his combo. OP, did you degree that cam? It could be a bad grind. It's been known to happen.
Old Mar 8, 2018 | 02:21 PM
  #55
BudRacing's Avatar
I think this was the intake test you mentioned.
http://www.hotrod.com/articles/20-ls...ifolds-tested/
Also,
Old Mar 8, 2018 | 02:43 PM
  #56
88bluchevy's Avatar
Cam wasn’t degreed because comp cam said in doing so would make a little more power down low and we were looking for power up top. Called Texas speed today and they recommend the tsunami v2 cam for my setup. It’s a 235/240 .629/.615 on a 111 lsa.
Old Mar 8, 2018 | 03:54 PM
  #57
why do they recommend such a large cam? ur shifting at 6400? id imagine u want to low 230s for intake and mid 230s for exh duration. again, no expert. call cam motion up for another opinion and see if their suggestion is similar to the one tsp recommended. when i messaged them they suggested a cam similar to urs, but im in an fbody that weighs 6-700 pounds less than u and im shifting at 6600 with a 6750 limit. sooooooo weight would your and my cam be similar when its for the most part 2 totally different applications? now i do know ur a 6.0 and im a 5.7, so maybe thats they're knowledge. which then maybe the cam is "suitable". if i were to do it over again, id go down to like a 232/236 for my ls1 instead of the 236/238 i have. my car does make good torque tho surprisingly. '
on a side note, it used to be well known around here that the 5.7s used to thrive with a cam in the very high 220s to under 235 range on both int and exh. now it seems like all the sponsors are on the "you wanna make power? gotta have a 240+ exh duration." maybe im wrong but thats just what ive been seeing and a lot of ppl are running. it seems people are running the 2 ends of the spectrum on their 5.7s lately, either low 220s on both int and exh, or high 230s touching 240s lately. did something change?
Old Mar 8, 2018 | 04:04 PM
  #58
Darth_V8r's Avatar
Moderator
I feel like something is off or restricting airflow somewhere and I doubt swapping the cam will help.
If you already checked the stuff out on the thread that were suggestions, disregard, but before I swapped in a larger cam, I would definitely make sure nothing simple was out of whack
As to degreeing the cam, I do not think it was being suggested to change your cam timing so much as to verify it is what it's supposed to be. I had a cam ground nine degrees off once.
Old Mar 8, 2018 | 06:10 PM
  #59
84c10's Avatar
If you change cams I've had great luck out of BTR stage 3 cams in heavy trucks. Mine makes well north of 400whp with one thru a 4l80
Old Mar 8, 2018 | 07:39 PM
  #60
kossuth's Avatar
Single 3” exhaust into magnaflow muffler. No cats and dumped before axle.
Quick question. Is the exhaust mandrel bent where you do have bends? You might not be breathing enough for that cam.
