which cam
Old Mar 8, 2018 | 08:03 PM
a70oldscutlass's Avatar
Default which cam
I have a 1970 442 with 3;42 gears , 3600 yank convertor , 4L60 , 2000 ls1 stock bottom end , tsp 2.5 243 heads , fast 92 intake with big mouth TB , direct port nos fogger (won't be used much) . I drive the car to shows and cruise ins and want it as fast as possible but drive decent . I have 3 cams to choose from , tsp 228 228 600 600 on a 112 ed Curtis custom 227 233 612 609 on a 111 and a tsp ms3 (forgot the specs) . One of the smaller cams will go in my 99 transam 3600 stall , 799 heads , Ls6 intake , 3;23 gears .
Old Mar 8, 2018 | 08:20 PM
HCI2000SS's Avatar
I like the specs on that Ed Curtis cam
Old Mar 8, 2018 | 08:44 PM
For the 442 ?
Old Mar 8, 2018 | 08:52 PM
HCI2000SS's Avatar
Yes out of the 3 you listed I think it's the best overall fit on that 442. If you had more gear and stall i'd lean more towards the MS3 specs
Old Mar 8, 2018 | 09:02 PM
I have 3;73 and 4;10 rearends for the car but I was wanting decent gas mileage for long trips. I also have 3;73 gears for the transam .
Old Mar 8, 2018 | 09:14 PM
HCI2000SS's Avatar
Just to give you an idea, I run a cam very similar to the MS3 but on a 6.0 with PRC 5.3 heads, 4.10's with a M6, and 11.5:1 compression. And even with my setup I wouldn't want a cam much bigger
Old Mar 8, 2018 | 09:19 PM
qweedqwag's Avatar
The TSP 228R is an awesome cam, had it in my 01 bird, made 401 hp with an old wore out engine.
Old Mar 8, 2018 | 09:28 PM
Deguila's Avatar
Ed Curtis in the 442. It would make good use of the heads and intake. Put the 228 in the TA with the 3.73gear. Save the MS3 for a track build. JMO, they both will be a hell of a lot of fun!
Old Mar 9, 2018 | 08:09 PM
Will the Ed Curtis cam sound much different than the 228r and how much more power will it make?
Old Mar 9, 2018 | 08:20 PM
HCI2000SS's Avatar
That Ed Curtis cam might thump a tad harder than the 228r cam, but i think you'll be hard pressed to actually hear the difference. It might make 5-10 hp more at best
Old Mar 9, 2018 | 10:00 PM
Thanks
