Cam grind
Old Mar 19, 2018 | 12:43 AM
yukio's Avatar
Default Cam grind
Hi.
I have a broken lifter and a bad cam.
When i pulled the cam it looked like the base of the cam(not the lobes) also was worn.
Does this look normal for you guys?
Comp cam from about 2012 with about 5000miles.
The reason i am asking is because i am wondering if there something else wrong with the engine, not just the lifter/cam, that coukd have caused patterns like that.
Thanks
Tommy
Old Mar 19, 2018 | 02:52 AM
jetech's Avatar
Veteran: Air Force
Looks like part of the broken lifter might have scored up the cam between the lobes
