Ms4 vs ms3
Hey guys, I have a 2000 WS6 its a M6. With .410s and 100 shot. I will be staying at 100 on the nitrous for a while. I want the car to run mid to low 12s at elevation. I would like to the car to trap 110. How realistic those goals are Im not sure.
I am looking at a cam now though....
So the MS4 239/242 649/600 111.5 lsa or the MS3 238/242 600/600 110 lsa.
Which of of these cams would get me to my goal or closer to it?
Also. If I am way off track and neither of these cams would. I am open to suggestions.
I'm pretty sure both of those cams will respond well to nitrous. I run a cam almost identical to the MS3, and on a 150 shot it hits very hard and pulls very strong. Both those cams will be within 5-10 hp of each other, with the slight edge to the MS4
Hey guys, I have a 2000 WS6 its a M6. With .410’s and 100 shot. I will be staying at 100 on the nitrous for a while. I want the car to run mid to low 12’s at elevation. I would like to the car to trap 110. How realistic those goals are I’m not sure.
Mild bolt ons and full weight too. There's plenty that go 11's with better bolt ons and weight reduction.
Big cam and nitrous should put you in the 10's no problem.
That's in lower-ish elevation
You'll be up to a second slower up there, but in my limited knowledge I would like to say it would be closer to .5-.7 seconds off.
Bolt ons and the spray should easily get you to your goal and beyond it.
Hi B-OPS, I have had a customer, Jeff McPherson, use my Intake/ECU/Coils in an engine assembled by S. Jennings Racing in Utah. This engine was "specked" for use at a 14K feet race. (Pikes Peak)
The Compression Ratio was 18:1, large intake ports, 65mm Eight Stack Intake (yes eight 2.5" butterflies)
I have IGN-1A coil customers, ProMod with NOS, that share engine spec information when they ask me about Spark Plug Gap/Coil Dwell settings.
Typically they ALL state a BIG Exhaust Lobe with NO2 spray AND WIDE Lobe Centers (121-124)
I use Nitrous Supply, Mike Themos, to supply my NOS items.
He states very similar "tech" in camshafts for NOS sprayed engines.
ANOTHER ITEM is a GOOD Squish of (.032") helps heat the combustion chamber air.
Thus my cam spec is one with a Large Exhaust Duration AND a Wide Lobe Center.
Thus my C.R. spec for your altitude is 12:1 +
Lance
Lance
