Is it worth it to port my set of 243s
If the $350 porting only gained 10 hp that's well worth it in my opinion. $35 per hp is a good deal. I think proper porting with a good valve job will gain 25hp to 30 hp.
You said you're already getting bowl work and a valve job and you got 25 hp from that? Is that what you meant?
I would expect roughly 30 (25-35) over stock heads, so if you're already getting 25, there isn't much left there to gain, but there is some. 10-15 ish, so depends on how much you want to spend to get there. Of course these numbers could go a little higher or lower, it's hard to accurately guess at it.
I'm really curious what they would get from the port work.
You said they already did the valve job, but you didn't say if they did the bowl work, i'd definitely get the bowl work done, the port work will be up to you and $$$ per hp.
so I got a steal by being buddies with them
here's some pics I'd go pull apart the motor on my 2014 truck if I could get bowl work and valve job for $100
