performance heads
Old Apr 14, 2018 | 01:49 PM
John helsley's Avatar
Default performance heads
does anyone have any suggestion for heads for my 5.3 build .
Old Apr 14, 2018 | 01:50 PM
5.3 with flat top pistons
Old Apr 14, 2018 | 02:19 PM
What year is your engine? If it's a Gen IV you already have either 243 or 799 heads. If so, maybe get a mild port job.
If the engine is Gen III, just get them ported and larger valves put in. TSP has their Stage 2.5 that does the above for $950, add about $160 for good beehive springs. These heads would flow only slightly less than the ported 243/799's
Old Apr 14, 2018 | 09:30 PM
garygnu's Avatar
the small bore will limit your valve size .
