2000 camaro z28 Hesitation Problem
The car has a 228 Texas speed cam, Slp intake, catless straight pipe with a cherry bomb muffler on stock manifolds.
Ive replaced both O2 sensors, spark plugs and wires, clean MAF sensor, replaced ect sensor(a few times).
The hesitation has been going on for some time but I finally got a service engine light. Codes p0171 and p0174 Lean in bank 1 & 2.
Not sure what to do any suggestions would help. Thank you.
Start there.
I've had a similar complaint in the past after a customer replaced their spark plugs and they had cracked several of them putting them in.
Are you getting any misfire codes? Does the check engine light flash while driving?
Start with the filter, it's the easiest and cheapest thing to do. But probably gonna wind up getting into the pump. And clogged filters kill pumps so if your filter is really clogged the pump may also be bad or on it's way out.
