Lifter stuff........
Old May 16, 2018 | 11:07 PM
BlkOps's Avatar
Default Lifter stuff........
So I have a 2000 trans am. 4.10 gears, 1 7/8th headers, 100 shot, slp lid and egr delete.
The car is going to get an MS3 cam. The car ONLY has 50k miles. 48K miles 100% stock.
The cam will be here tomorrow and it is being installed on sunday. So I need to figure out if I need to do a new chain and gear and if I need to do different lifters.
Couple questions:
First do you guys strongly think I need to do a new timing chain and/or cam gear?
Second can I leave the stock lifters? I am considering doing heads in the near future after an intake.
Thanks in advance,
Old May 16, 2018 | 11:41 PM
Couple questions:
Thanks in advance,
You will need different springs to handle the added lift. All else can stay.
Old May 17, 2018 | 12:30 AM
BlkOps's Avatar
I will be doing .660 dual springs when I install the cam along with harden pushrods.
Thank you for the quick response!
Old May 17, 2018 | 07:28 AM
thompson's Avatar
If you are doing the heads put some lifters in it. If not let it ride until the heads come off. The stock ones chatter with a stock cam and will likely make a little more noise with the new one but generally will not come apart too quickly. Oil pressure seems to help with the noise, It is never a bad idea to throw a good pump on the car while in there. Something like a melling 10295 is cheap insurance, they run $119.99 and will stay with the car and motor as you continue to upgrade everything around it. Let me know if you need any help sourcing any of the parts, I keep them in stock and can have them out usually same day or next day.
Thank you,
Kyle
Thompson Motorsports
Kyle@thompsonmotorsports.net
972-853-2450
Old May 17, 2018 | 10:34 AM
pantera_efi's Avatar
Default Split Overlap Cam Timing
Hi BlkOps, the chosen camshaft should be installed at Split Overlap.
This will require a timing set with index positions on the crank sprocket.
I sell the Avon Gear billet timing set, the strongest of all sets.
I too would replace the Oil Pump, I fit the OEM 2010 Camaro pump for a $90.00 dollar dealer cost.
I sell the Billet TS for $158.00 + $10.00 for USPS.
I can ship today USPS, you will have the item Saturday.
Lifters need to be tested by "rolling" the bearing with your fingers feeling for a rough "roll" would be a reason NOT to use that set.
I would replace the plastic trays as the cost is LOW.
Lance, BTW this IS the strongest chain, the ONLY one with Oil Lubrication holes !
