Will this 6.0 combo work well for Daily?
Junk Yard LQ4 long block and keeping original heads on it, adding Ls6 intake and all LS1 parts from another engine including drive accessories and headers, but wanting to insert TSP 228R .588/.588 112LSA CAM. Friend told me to ask the question here if there are any gotchas I might be missing and to ask what sorts of power this would realisticly make? Note will go in a roller F-Bod that has Vig Stall and A4. thanks mucho!
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
2006
Engine Assembly
Chevy Truck Silverado 2500 6.0,AT,VIN-U,TESTED,NOTE e2216 HH0399 $900
So with everyone's suggestions taken into consideration, here is where I am landing for my recipe so far:
2006 Silverado Lq4
Stock unported unshaved 862 Truck heads with dual springs and hardened pushrods
Ls6 intake and long tubes
228R cam TSP 228R .588/.588 112LSA
All other accessories from LS1 carried over
To be used in an FBody A4 with existing stall like 3200 I think for DD use and occasional weekend strip, 3.73's
Q1: Does this recipe need custom length pushrods or any other gotchas I might be missing?
Q2: Any idea on power this recipe would be at the tire?
Thank you all
I am ready to pull the trigger on this combo and not feeling too confident, this is going to be my first venture into swapping LS engines and I know I am going to make mistakes but I'd like a good foundation to start with. Any input would be greatly appreciated on this engine/head/cam recipe.
https://ls1tech.com/forums/generatio...l#post19905917
I got 10.29 using summit racing's compression calculator. So yes 10.2x is correct.
The 6.0 with those heads and that compression and that cam will be a very fun driver. It'll have power everywhere and be pretty tame (tame meaning the cam isn't so big that it makes driveability go to ****). With that cam you'll need springs and hardened pushrods. With the drop in truck cams you can use stock push rods and you'll need to get some fresh LS6 valve springs, they're $70 ish
I would go with the 228 or slightly larger, instead of the truck cam.
Go ahead and do the bushing trunion upgrade while you're in the engine, don't do the roller bearing style, do the bushing style. The bearing style is showing to not last very long, many people have had issues with them. I believe TSP and WS6 store sell new upgraded factory style rocker arms too. Check with them.
While you have the engine out go ahead and replace all the seals, including cam and crank sensor o rings. While you have the oil pan off do the oil pump pick up tube o ring. If you do the oil pump pick up with the oil pan off there's little chance of tearing the o ring, if you leave the pan on and change the o ring there's a good chance you'll tear the o ring. Leaving the pan on at this point is silly since the motor is out, plus oil pan gaskets are a regular failure item anyway.
Get with WS6store ( tech@ws6store is his screen name ) on here and he can set you up with a package deal on seals rockers/bushings, cam components etc. Lance ( pantera_efi )sells a really nice timing chain and gears that doesn't cost much.
I was doing something wrong on the compression calc, It's actually 10.76 with the 61.15 cc chambered heads. But 10.76 and that cam and premium fuel should make for a fun motor.
You could also do 243/799 heads and have 10.35:1
