The rotary engine is actually a remarkable engine. They are usually only "1.3 liters", however what people don't realize is that at any point during the rotors rotation, 1 side of the rotor is performing either intake, igniting, or exhaust. All at the same time. Plus the eccentric shaft rotates 1 for every 3 times a rotor turns. The problem with the engine is that it is not "torquey", and you need big ports that are not streetable to make good power, and you need to rev it to the sky. Oh, and a rotary engine only detonates once. And they are loud as heck. The interesting thing is that your peak power is actually determined by the length of your header, and/or entire exhaust system, before you join the two.
I have a great idea though. I was thinking about how to make the most efficient head. Here is what you need...Star Trek forcefield technology. Then you just have little forcefields open and close, allowing for absolutely perfect airflow. Unfortunately I don't know how to make a forcefield....hmmm.
P.S. That is just a joke.
