Tfs 235 vs. Prc 247
Old Jul 9, 2018 | 04:22 PM
Philhippy45's Avatar
Default Tfs 235 vs. Prc 247
I have a 6.0 That I am stroking to a 408. I have a fast 102 intake, -3cc pistons, Texas giant cam, 42lb injectors, trunion upgrade, ls2 chain, tsp 4" forged crank. I think that's about all that's needed. But what do you guys think? Is 2000 good for a used set of tfs or should i spend the extra 400 for the tsp 247 which are better in terms price to cfm are the 247 really much better both have the same valves and both have the .660 Springs. What's everyone's opinion.
Old Jul 9, 2018 | 04:51 PM
SRT8.Acelleration's Avatar
You don't make a cylinder head decision on cfm numbers alone. You need to do a little math and talk to the experts first to see what your combination requires. High cfm doesn't mean its good for your motor and high cfm / big ports can actually reduce power from your engine. You might make alot more TQ with a smaller port/cfm numbers then you would with high cfm numbers -- airspeed is what matters, CFM numbers sell parts, high airspeed with correct port size/valve size wins races.
Old Jul 9, 2018 | 09:04 PM
Gooze_1's Avatar
I'd go with the tfs 235s
Old Jul 10, 2018 | 01:14 AM
Tuskyz28's Avatar
Go with TFS 245s finished by Brian Tooley
You'll run 10s with ease doing so.
Old Jul 10, 2018 | 10:32 AM
well that's the thing I can get either the prc 247s a set of tfs 235s or now maybe a set of ls6 heads done up by cbm. If I can save money but still getva good head that will compliment my setup id be happy.
Old Jul 10, 2018 | 10:52 AM
Tuskyz28's Avatar
Why you stuck on the 235 tfs heads instead of the 245 tfs heads....
Old Jul 10, 2018 | 11:10 AM
cuz I can get the 235s cheaper lol
Old Jul 10, 2018 | 12:32 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Agreed, between the two choices, TFS 235s.
Especially with that Giant Cam, better performance & drivability.
Old Jul 10, 2018 | 01:37 PM
So far 2 for the 235s
Old Jul 10, 2018 | 03:33 PM
99 Black Bird T/A's Avatar
Probably worth getting some expert opinions from the various vendors etc.
FWIW in my limited experience it's usually better to go with the head that has the smaller port volume when picking between two similar heads that can meet your goals. Usually the higher velocity of the slightly small port will drive better and usually make the same or better power with the correct cam.
I'd go with TFS 235's over the PRC 247's for your 408.
Old Jul 11, 2018 | 06:09 AM
So far 3 people are saying 235 over 247. Im looking to at least get 5 before i pull the trigger.
Old Jul 11, 2018 | 10:33 AM
OK, here's one more...
Old Jul 11, 2018 | 10:50 AM
READ THIS FIRST
http://darinmorgan.net/frank-talk-about-flow-numbers/
Old Jul 11, 2018 | 11:38 AM
JakeFusion's Avatar
Super Hulk Smash
Frankenstein 237s...
Old Jul 12, 2018 | 09:41 PM
big hammer's Avatar
TFS heads are a nice beginner head
Old Jul 12, 2018 | 10:07 PM
Gooze_1's Avatar
What would be a step up from them?
Old Jul 12, 2018 | 10:25 PM
wannafbody's Avatar
Mast Small Bore LS3 heads but they are $$$$$$$$$$$$$
Old Jul 12, 2018 | 10:28 PM
Tuskyz28's Avatar
people say Mast.... I'm still waiting to see more track results myself. One car going fast with them don't tell me ****. I'm just saying.....
Old Jul 12, 2018 | 10:37 PM
Gooze_1's Avatar
I've got mms 235s myself, I was just curious as in why the tfs are a beginners head
Old Jul 13, 2018 | 03:39 AM
Public Enemy's Avatar
Tfs 235
By Brett Foote | 2026-06-04 05:00:17
