Looking for ls1 mod ideas
Old Jul 11, 2018 | 07:33 PM
89_FIREFORM's Avatar
Default Looking for ls1 mod ideas
I have an ls1 off my 99 transam guessing stock heads for the year. It has ls6 intake,mac mid length headders,torquer v2 cam. Gmmg exhaust,shitty tune.slp lid. Now the car was just getting oil pan gasket done and the guy took out engine and gave me the short block. Has some rocker damage and could use some freshening up. Ive been out of the game for awhile so I don't know what would be good to do while its out. Like ls2 ls3 heads etc. Looking for advice for you guys. The car used to make 380rwhp lookong for more
Old Jul 11, 2018 | 08:19 PM
How much more power are you after? And be realistic. Keeping the Torquer V2 cam? I think a nice set of ported 243/799 heads would help it unless you want to go aftermarket like Trick Flow or AFR. You already have a good intake unless you have your eyes on a FAST, but I'm not sure you need it.
Old Jul 12, 2018 | 06:10 AM
Im after as much power i can get without breaking the bank, like everyone. Im lookin to keep v2 cam. But im open to ideas
Old Jul 12, 2018 | 07:17 AM
HCI2000SS's Avatar
With that cam a set of ported 243's would do well, or even just port the stock heads
Old Jul 12, 2018 | 01:01 PM
BlwnLs1GTO's Avatar
Cheapest would be to get a good aftermarket piston with Gen 4 Rods and increase compression for that Nitrous setup you'll be installing. A nice set of 243 heads as well.
Old Jul 12, 2018 | 01:17 PM
JustinZ's Avatar
Get rid of those mid length headers and get a good set of 1 7/8th long tubes. I agree with the above comments, heads would probably be the way to go.
Old Jul 18, 2018 | 11:19 AM
OK so I wanna do the 243 heads wondering if there are only certain years I can use on the ls1. Anything like 6.0 ls2? And im hearing about 799 heads.
Old Jul 18, 2018 | 11:22 AM
243 and 799 are basically the same head, and all are the same, no matter the year. LS6 engines came with different valves but the heads are the same.
Old Jul 18, 2018 | 12:06 PM
Cool,thanks. Its damn near impossible to find 243s but 799 are all over
Old Jul 18, 2018 | 01:17 PM
Yeah, you will NOT be shorting yourself with 799's. They are functionally identical to 243's. I think they use a different casting method on the 799's, which explains slight differences in appearance. Use 'em! They're GOOD! lol
Old Jul 18, 2018 | 02:07 PM
Im also thinkin of ls7 lifters, but not sure if mine are bad and ls2 timing chain while this things out
Old Jul 18, 2018 | 03:16 PM
LS7 lifters and LS2 chain will serve you well.
Old Jul 18, 2018 | 07:45 PM
Well now after taking engine apart my v2 cam is smoked and a lifter. One lobe is scored up. Im not sure if i should rebuy that cam or look at a btr stage 3 or whatever. Lookin for more advice
Old Jul 18, 2018 | 10:27 PM
Well, what would you change as far as characteristics of the V2?
Old Jul 18, 2018 | 10:33 PM
Tuskyz28's Avatar
Ls2 chains tend to stretch after 10k miles. Ls7 lifters are ok.... but morels 5315s ate better for only 40 bucks more.
Old Jul 19, 2018 | 06:34 AM
good to know about timing chain. but last night i went digging and tsp makes a torquer v4 cam. bit more lift but when i sent an email to those guys. someone replied with "v2 and v4 are both good cams but v4 is more fitting for a bigger intake and ported heads"
Old Jul 20, 2018 | 08:03 PM
Lookin at tsunami cam from tsp
