Cam for my 2002 camaro
Old Jul 31, 2018 | 01:30 PM
J-LS's Avatar
Default Cam for my 2002 camaro
quick questions. I am looking at a cam for my ls1 and I just wanted to know if it would be a good cam for driving and be good sounding. I don’t really want a really uncivilized if you know what I mean. It is a Hydraulic Roller, Advertised Duration 286/282, Lift .575/.575, Lobe Sep. 112. Thanks.
Old Jul 31, 2018 | 01:35 PM
What's the duration at .050" ?
And BTW, the LS1 is Gen III, not Gen IV.
Old Jul 31, 2018 | 01:41 PM
HCI2000SS's Avatar
The sound will also be dependant on your exhaust
Old Jul 31, 2018 | 01:47 PM
big hammer's Avatar
Wicked chop comes from overlap and that’s what makes them drive like crap. A Cam with 8-10* overlap can sound and drive decent
Old Jul 31, 2018 | 02:15 PM
J-LS's Avatar
This is what is shows for what gen the 2002 camaro is. It is confusing me getting different info. Any way what motor is in my car then? I was told and when I look it up with the vin it says it is a 5.7?https://en.m.wikipedia.org/wiki/Chevrolet
Old Jul 31, 2018 | 02:19 PM
J-LS's Avatar
this is the cam specs
TFS-30602002 - Trick Flow Camshaft, Hydraulic Roller, Advertised Duration 286/282, Lift .575/.575, Lobe Sep. 112, GM LS, Each
Old Jul 31, 2018 | 03:32 PM
They should show duration at .050" as that is what is usually quoted for comparison's sake.
Just googled it- 220/224. Pretty mild cam, should just lope a little. It will not sound stock.
Old Aug 1, 2018 | 12:31 AM
KW Baraka's Avatar
https://www.trickflow.com/parts/tfs-30602002 -2* overlap means that it will have a hint of a lope and drivability would be near stock.
KW
Old Aug 1, 2018 | 11:25 AM
dlandsvZ28's Avatar
Understand that you will need the car retuned. An inexperienced tuner might make a mild cam run like crap and a good tuner can make a mild cam run like stock.
Old Aug 1, 2018 | 11:37 AM
DANOZ28's Avatar
well i went too mild (ls6), i would say no less than 224 / 224 duration , call a few sponsors and get a pros opinion. maybe i missed it do you have a stick or auto? if auto will you add a stall? yes you'll need a tune after. better springs are very important.
