just to clearfiy about the crank bolt
Old Jul 7, 2004 | 05:37 PM
68birdls1's Avatar
Default just to clearfiy about the crank bolt
i have done some research but nothing that is really clear about what the best way to do it is. i am talkin about putting the pulley back on. i just read somewhere about using a threaded stud with a nut and a couple of washers to put the pulley on. now if i do it that way can i use the stock crank bolt? and will it be ok. and if i do need to buy a longer crank bolt, where is the best place to get one at? thanking you in advance!
daniel
Old Jul 7, 2004 | 06:03 PM
felton316's Avatar
Yes, you can use the threaded rod and a nut to install the pulley. Once the pulley is seated, you will remove the threaded rod and then use a new stock crank bolt to keep the pulley on.
Old Jul 7, 2004 | 06:24 PM
Got Me SOM's Avatar
clearify?
Old Jul 7, 2004 | 07:09 PM
soundengineer's Avatar
it is much smarter to just get a new one.
The old one will have been stretched and will not torque down correctly..... takes way less effort to put on a new one correctly
but you can use the old bolt to seat the pulley properly after using the rod and nut with washers to pull it on...
Grab your biggest torque wrench and attempt to torque that old bolt down to 240lbft. Now, break the bolt free and remove it.
Take your NEW crank pulley bolt and thread it in all the way by hand. Torque this bolt to 37lbft. Now, we need to stretch the bolt into place. Get your breaker bar and pipe extension, and try to turn the bolt 140degrees past where it is at now...
it is easiest to mark the bolt with a line across it so you can get the degree's right.
(140* is 90* + a little past another 45*)
Old Jul 7, 2004 | 08:10 PM
68birdls1's Avatar
so after i turn the bolt 140*, do i try and torque it down to 240lbs? or just leave it where it is after i turned it 140? thanks for all the help. would the best place to get the new crank bolt be at gm? thank you!
daniel
Old Jul 7, 2004 | 08:21 PM
once you do the 140* you are done...
Old Jul 7, 2004 | 08:36 PM
MechMan's Avatar
screw that, just impact it on. there done
Old Jul 7, 2004 | 08:38 PM
68birdls1's Avatar
all right, thanks alot! i really appreciate the help.
daniel
Old Jul 7, 2004 | 08:39 PM
and when it comes off... it will do a lot of damage.....possibly to other peoples cars if it hits them......
always do stuff to proper torque specs
Old Jul 7, 2004 | 08:41 PM
MechMan's Avatar
We have done probably 40-50 that way.
The only ones we have ever seen fall off are the one done the way you are tellin him
Old Jul 7, 2004 | 08:46 PM
We have done probably 50-70 that way.
I'm stating the way GM recommends... it is a torque to yield bolt...
it is made to stretch into place..... by going 140* after 37ft/lbs
Old Jul 7, 2004 | 08:53 PM
MechMan's Avatar
Ya Iknow but after we have seen at least 3 of them fall off, from people using that. And it does alot of damage. Headers takin out wheels destroyed. Oil pans just gone. Now I dont know if they used new bolts either. But
we have been installing them with the impact for a few years now.
And never had 1 problem
Old Jul 7, 2004 | 09:00 PM
BLUEBALLS ZZ's Avatar
so very true.
Old Jul 7, 2004 | 09:22 PM
Snow Dog's Avatar
140* past 37ftlbs is a whole lot of moving. not as easy as it sounds. use a thread rod get some washers and lube them up good or better yet go get a wheel bearing from autozone and use that with a washer. thread the new balancer on that way. take the old bolt and use it put the balancer the rest of the way on if need be, then get a brand new GM bolt or arp if you like and put it in. use antiseize or oil to lube it. hit it with a very strong gun using impact sockets only(they fit tighter to minimize slippage). hold it there until you see the bolt no longer turning. done voila it shouldnt move.
note the balancer must be seated before you put the impact on it and use the new bolt. and when i say strong impact im talking half inch drive, breaks cross threaded bolts off when necessary strong. do not use some weak *** 3/8 impact it its not strong enough.
Old Jul 7, 2004 | 10:16 PM
fast98's Avatar
who here actually thinks gm techs torque stuff down??? really i work at a chevy dealer the heavy techs put head bolts in with there impacts.
Old Sep 6, 2004 | 05:34 PM
jerflash's Avatar
hey does anyone know the torq spec if you use an arp crank bolt?
you put the pully on there with the threaded rod then you put the arp bolt in but i know that bolt wont stretch
Old Sep 7, 2004 | 08:53 AM
Paul F's Avatar
Sorry man but we've done way more pulleys then that doing it the correct way and we've never had a single one come off. Have you personally done one the correct way and had one come off? I don't think so. The one's that have come off I can bet that they either didn't follow the correct specs or didn't use a new bolt.
An impact gun is not the way to put a pulley on and nor is it good for the bearings.
Old Sep 7, 2004 | 08:57 AM
DAPSUPRSLO's Avatar
Chances are if you have done it by GM specs and it has come off you re-used the stock bolt. Ask me how I know. I have had mine on and off many a times and have never had a problem until I used a re-used stock bolt accidentilly. I now have the ARP on there with lock-tite and no problems since.
Old Sep 7, 2004 | 09:02 AM
ZO6 LandRocket's Avatar
Amen!
Old Sep 8, 2004 | 04:30 PM
AthensLS1's Avatar
"Threaded rod with a nut"
Anyone know what length and diameter rod I should buy for this? I've got a busted asp crank pulley and need to install this stocker.
Thanks
