LQ4 Build, custom cam spec explained
As for lifter; ls7 / morel 5315 / Johnson 2110 ?
im sure all will work, but which one is the most practical choice?
I have shifted them at 7400 with jesel sportsmans, btr duals, and manton 201's
The exhaust opening is also pretty conventional at 53 bbdc and it's the least critical of the four events, so I'll leave that there. The odd thing about this cam is the exhaust closing point. It's at 9 atdc...which at first glance appears to have a lot of overlap and what makes the exhaust duration "look" long in relation to the intake duration. In reality, the intake valve isn't open much and reversion is less than what overlap would suggest. A nitrous cam would put those 6 extra degrees on the exhaust opening side...which would be seen as more lobe separation.
To compare this cam to our SUM-8707 stage 2 cam (226/238 113 + 3), ours has the following events IVO 3 btdc, 43 abdc IVC, 55 bbdc EVO, 3 atdc EVC. By the numbers, ours would have a more aggressive idle, similar powerBand (not power), and the exhaust closing would be nearly the same (you could think of that as loudness)...then we've closed our exhaust valve 3 degrees earlier. We did that for a couple reasons. One of which is most cars this cam will go in have a closed exhaust system with slightly higher back pressure than open headers. With our intake valve opening btdc, it's more sensitive to overlap both from piston motion and residual exhaust from blowdown.
So his cam is a little strange if you are just looking at the duration split, but no one-thing is going to kill it strictly in terms of timing events. The lift is on the higher side. If JoeNova is correct about the lobe choice, using an aggressive EHI lobe on the intake and supersoft SLW on the exhaust for this application is strange if that's indeed what they are..
In for results also...
You mean there is more to a cam than just the @.050 numbers?
Internet you failed me.....
