Whats needed for cam swap
Old Aug 30, 2018 | 05:31 PM
tberg725's Avatar
Default Whats needed for cam swap
So i am going to be swapping heads and installing my cam here shortly what all is recommended to do during the cam swap? Should the oil pump be changed? Lifters?? Id imagine the timing chain should be changed??
Currently waiting on new head bolts because i refuse to reuse head bolts but what all should i replace while doing this?
Thanks for taking the time to reply all
Old Aug 30, 2018 | 05:48 PM
jetech's Avatar
Veteran: Air Force
pretty much as you stated... timing chain,oil pump,lifters,head bolts, head gaskets and measure for push rod length to achieve the correct amount of lifter preload. So you might have to purchase new push rods. You could also measure to figure the quench dimension to figure the optimal head gasket thickness, which might slightly raise the C.R. While the front cover is off I would replace the seal
Old Aug 30, 2018 | 05:50 PM
HCI2000SS's Avatar
What heads and cam are you doing?
Old Aug 31, 2018 | 07:58 PM
Utinator's Avatar
You will need a lot of new seals. I had a thread on here earlier this week. The WS6 Store put a list together for me. It should be around here somewhere.
Old Aug 31, 2018 | 10:23 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Head bolts
Head gaskets
Valve cover gaskets
Valve seals
Exhaust manifold gaskets
Front cover gasket kit
Crank bolt
Lifters
Oil pump
Timing set
Thrust plate
Intake manifold gaskets
Water xover gaskets
Optional if look bad
Valley cover gasket
Knock sensor grommets
Knock sensors
Knock sensor harness
That covers every area
Thanks
Ws6store
Old Sep 1, 2018 | 10:37 AM
wannafbody's Avatar
Might want to reseal the oil pan at the same time, especially if it looks moist.
Old Sep 1, 2018 | 11:42 AM
Old Sep 1, 2018 | 11:48 AM
OK Tech, it was just a LITTLE too early in the AM to see that.... BTW 5 in the PM is STILL too early....
Old Sep 1, 2018 | 11:57 AM
Her neck really makes the whole picture worth it.
Old Sep 1, 2018 | 01:08 PM
5.7stroker's Avatar
This. I made my own excel sheet so that I could figure out all the math behind the theoretical calculations.
https://drive.google.com/file/d/1MDT...CcBIIrpiv/view
