5.3 bore to 5.7 piston question
I bore out my 5.3 to a 5.7 and was planning on using the same rods and crank but i was wondering what pistons i should use i was planing on using this ls1 aftermarket Diamond power pistons question is will they work on my rods?
Diamond Power LS1 pistons are oem replacement , they are press pin .So if you're 5.3 rods are pre 2004 they will work.
