Procharger build
Old Oct 8, 2018 | 01:55 PM
IvAAssassin's Avatar
Default Procharger build
I have a 5.3 silverado and I am wanting to know what all do I need to do to my motor to be able to handle a procharger?
Old Oct 8, 2018 | 02:19 PM
JoeNova's Avatar
Restricted User
Nothing.
Old Oct 8, 2018 | 02:20 PM
Ok I wasnt sure if I had to upgrade it like if I did nitrous
Old Oct 8, 2018 | 03:01 PM
ddnspider's Avatar
Nothing motor wise as Joe said, but you'll wany to do fuel injectors and a pump.
Old Oct 8, 2018 | 03:23 PM
Ok cool any suggestions? I'm new to this
Old Oct 8, 2018 | 06:09 PM
ddnspider's Avatar
Either 60 or 80lb high impedance injectors and either a walbro 340 or 450 depending on hp goals
Old Oct 8, 2018 | 06:11 PM
I like to eventually get at least 500 rwhp
Old Oct 8, 2018 | 06:54 PM
ddnspider's Avatar
60lbers and a 340 is fine with room to grow.
Old Oct 8, 2018 | 06:56 PM
So dont go for the 80lb and higher pump?
Old Oct 8, 2018 | 07:14 PM
ddnspider's Avatar
Not unless you want north of 600whp. 60lbers will actually handle 600whp,but you'd want the 450.
Old Oct 8, 2018 | 07:18 PM
I'm mean I'll wanna go as high as I can go with my 5.3 without having to buy a new motor
Old Oct 8, 2018 | 07:44 PM
JoeNova's Avatar
Restricted User
Isnt your 5.3 a gen 4?
Old Oct 8, 2018 | 07:49 PM
Idk I couldn't tell you I think it's a lmg 5.3 I think is what it said when I looked up vin
Old Oct 12, 2018 | 01:40 PM
conan's Avatar
What year is the 5.3L
Old Oct 12, 2018 | 02:18 PM
JoeNova's Avatar
Restricted User
LMG is a gen 4.
Old Oct 14, 2018 | 10:52 AM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
60pph injectors also means your tune will not need to be scaled. Adding meth injection on top of this will give you a good cushion. A 450lph pump and a hot wire/Boost-A-Pump are a good upgrade for the stock power supply.
Beyond that, you can probably put 10-12lbs into the engine to make your power goals with a D1SC (skip the P1 - pay the extra money on this for later). Nothing else is required other than a good tune.
Decent headers would be a bonus.
