Opinion on this cam for a daily driver Tahoe?
Planning ahead to camming my 2011 Tahoe with the 5.3L and 6L80E. I don't want to run an aftermarket converter. It will have longtubes, trunnion upgrade, DOD/AFM delete, CAI and dyno tune. The truck has 3.42 gears. I am looking at
- 212/218 Duration at .050". 115 Degree Lobe Separation Angle.
- .558"/.563" Valve Lift w/ 1.7 Ratio Rocker Arm
Moderator
Received 1,838 Likes
I would definitely advance that cam at least 4 degrees to gain low end torque. Maybe even six degrees. Especially if your compression ratio is still stock. it will taper off a bit earlier up top, but with that heavy tahoe, I would sacrifice high RPM for low end grunt myself.
