Ls9 Swap
Old Nov 24, 2018 | 01:29 PM
EngineNoob's Avatar
Default Ls9 Swap
So I have a 99 silverado with a 5.3 and was thinking of putting a Ls9 cam along with valve springs and lifters into it. I know there are better cams out there but I'm doing this all on a budget and seeing as I already have those components Id like to go ahead and use them. My main questions are: What are the advantages/disadvantages with this cam, and what all other components should I gather in order to do this job. Other than new gaskets of course. Keep in mind the only thing done to it thus far is cold air intake and a tune. Thank you in advance.
Old Nov 24, 2018 | 02:11 PM
Advantages- cheep, upper end performance improvement.
Disadvantages- loss of low end torque, and in a truck you do not want that. Get an LQ9 cam for good all around improvement.
Old Nov 24, 2018 | 06:25 PM
EngineNoob's Avatar
If I decided to go ahead with the ls9 swap would I need a 4th gen timing cover an can sensor? I’ve heard two different things.
Old Nov 24, 2018 | 08:31 PM
I think so. The LS9 is a Gen IV engine which uses the front cam sensor.
